Migrate from a Cisco storage switch to a NVIDIA SN2100 storage switch
You can migrate from older Cisco switches for an ONTAP cluster to NVIDIA SN2100 storage switches. This is a nondisruptive procedure.
Review requirements
You must be aware of certain configuration information, port connections and cabling requirements when you are replacing some older Cisco switches with NVIDIA SN2100 storage switches. See Overview of installation and configuration for NVIDIA SN2100 switches.
The following storage switches are supported:
Cisco Nexus 9336C-FX2
Cisco Nexus 3232C
For details of supported ports and their configurations, see the Hardware Universe.
Ensure that:
The existing cluster is properly set up and functioning.
All storage ports are in the up state to ensure nondisruptive operations.
The NVIDIA SN2100 storage switches are configured and operating under the proper version of Cumulus Linux installed with the reference configuration file (RCF) applied.
The existing storage network configuration has the following:
A redundant and fully functional NetApp cluster using both older Cisco switches.
Management connectivity and console access to both the older Cisco switches and the new switches.
All cluster LIFs in the up state with the cluster LIfs are on their home ports.
ISL ports enabled and cabled between the older Cisco switches and between the new switches.
Some of the ports on NVIDIA SN2100 switches are configured to run at 100 GbE.
You have planned, migrated, and documented 100 GbE connectivity from nodes to NVIDIA SN2100 storage switches.
Migrate the switches
In this procedure, Cisco Nexus 9336C-FX2 storage switches are used for example commands and outputs.
The examples in this procedure use the following switch and node nomenclature:
The existing Cisco Nexus 9336C-FX2 storage switches are S1 and S2.
The new NVIDIA SN2100 storage switches are sw1 and sw2.
The nodes are node1 and node2.
The cluster LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
The
cluster1::*>prompt indicates the name of the cluster. -
The network ports used in this procedure are e5a and e5b.
Breakout ports take the format: swp1s0-3. For example four breakout ports on swp1 are swp1s0, swp1s1, swp1s2, and swp1s3.
Switch S2 is replaced by switch sw2 first and then switch S1 is replaced by switch sw1.
Cabling between the nodes and S2 are then disconnected from S2 and reconnected to sw2.
Cabling between the nodes and S1 are then disconnected from S1 and reconnected to sw1.
Step 1: Prepare for migration
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=xhwhere x is the duration of the maintenance window in hours.
Change the privilege level to advanced, entering y when prompted to continue:
set -privilege advancedThe advanced prompt (*>) appears.
Step 2: Configure ports and cabling
Determine the administrative or operational status for each storage interface.
Each port should display enabled for
Status.Display the network port attributes:
storage port showShow example
cluster1::*> storage port show Speed VLAN Node Port Type Mode (Gb/s) State Status ID -------------- ---- ----- ------- ------ -------- --------- ---- node1 e0c ENET storage 100 enabled online 30 e0d ENET storage 0 enabled offline 30 e5a ENET storage 0 enabled offline 30 e5b ENET storage 100 enabled online 30 node2 e0c ENET storage 100 enabled online 30 e0d ENET storage 0 enabled offline 30 e5a ENET storage 0 enabled offline 30 e5b ENET storage 100 enabled online 30 cluster1::*> -
The storage ports on each node are connected to existing storage switches in the following way (from the nodes' perspective) using the command:
network device-discovery show -protocol lldpShow example
cluster1::*> network device-discovery show -protocol lldp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- -------------- ---------------- node1 /lldp e0c S1 (7c:ad:4f:98:6d:f0) Eth1/1 - e5b S2 (7c:ad:4f:98:8e:3c) Eth1/1 - node2 /lldp e0c S1 (7c:ad:4f:98:6d:f0) Eth1/2 - e5b S2 (7c:ad:4f:98:8e:3c) Eth1/2 - -
On switch S1 and S2, the storage ports and switches are connected in the following way (from the switches' perspective) using the command:
show lldp neighborsShow example
S1# show lldp neighbors Capability Codes: (R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device, (W) WLAN Access Point, (P) Repeater, (S) Station (O) Other Device-ID Local Intf Holdtime Capability Port ID node1 Eth1/1 121 S e0c node2 Eth1/2 121 S e0c SHFGD1947000186 Eth1/10 120 S e0a SHFGD1947000186 Eth1/11 120 S e0a SHFGB2017000269 Eth1/12 120 S e0a SHFGB2017000269 Eth1/13 120 S e0a S2# show lldp neighbors Capability Codes: (R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device, (W) WLAN Access Point, (P) Repeater, (S) Station (O) Other Device-ID Local Intf Holdtime Capability Port ID node1 Eth1/1 121 S e5b node2 Eth1/2 121 S e5b SHFGD1947000186 Eth1/10 120 S e0b SHFGD1947000186 Eth1/11 120 S e0b SHFGB2017000269 Eth1/12 120 S e0b SHFGB2017000269 Eth1/13 120 S e0b -
On switch sw2, shut down the ports connected to the storage ports and nodes of the disk shelves.
Show example
cumulus@sw2:~$ net add interface swp1-16 link down cumulus@sw2:~$ net pending cumulus@sw2:~$ net commit
Move the node storage ports of the controller and disk shelves from the old switch S2 to the new switch sw2, using appropriate cabling supported by NVIDIA SN2100.
On switch sw2, bring up the ports connected to the storage ports of the nodes and the disk shelves.
Show example
cumulus@sw2:~$ net del interface swp1-16 link down cumulus@sw2:~$ net pending cumulus@sw2:~$ net commit
The storage ports on each node are now connected to the switches in the following way, from the nodes' perspective:
Show example
cluster1::*> network device-discovery show -protocol lldp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ------------- ---------------- node1 /lldp e0c S1 (7c:ad:4f:98:6d:f0) Eth1/1 - e5b sw2 (b8:ce:f6:19:1a:7e) swp1 - node2 /lldp e0c S1 (7c:ad:4f:98:6d:f0) Eth1/2 - e5b sw2 (b8:ce:f6:19:1a:7e) swp2 - -
Verify the network port attributes:
On switch sw2, verify that all node storage ports are up:
Show example
cumulus@sw2:~$ net show interface State Name Spd MTU Mode LLDP Summary ----- ------ ---- ----- ---------- -------------------- -------------------- ... ... UP swp1 100G 9216 Trunk/L2 node1 (e5b) Master: bridge(UP) UP swp2 100G 9216 Trunk/L2 node2 (e5b) Master: bridge(UP) UP swp3 100G 9216 Trunk/L2 SHFFG1826000112 (e0b) Master: bridge(UP) UP swp4 100G 9216 Trunk/L2 SHFFG1826000112 (e0b) Master: bridge(UP) UP swp5 100G 9216 Trunk/L2 SHFFG1826000102 (e0b) Master: bridge(UP) UP swp6 100G 9216 Trunk/L2 SHFFG1826000102 (e0b) Master: bridge(UP)) ... ...
On switch sw1, shut down the ports connected to the storage ports of the nodes and the disk shelves.
Show example
cumulus@sw1:~$ net add interface swp1-16 link down cumulus@sw1:~$ net pending cumulus@sw1:~$ net commit
Move the node storage ports of the controller and the disk shelves from the old switch S1 to the new switch sw1, using appropriate cabling supported by NVIDIA SN2100.
On switch sw1, bring up the ports connected to the storage ports of the nodes and the disk shelves.
Show example
cumulus@sw1:~$ net del interface swp1-16 link down cumulus@sw1:~$ net pending cumulus@sw1:~$ net commit
Show example
cluster1::*> network device-discovery show -protocol lldp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- -------------- ---------------- node1 /lldp e0c sw1 (b8:ce:f6:19:1b:96) swp1 - e5b sw2 (b8:ce:f6:19:1a:7e) swp1 - node2 /lldp e0c sw1 (b8:ce:f6:19:1b:96) swp2 - e5b sw2 (b8:ce:f6:19:1a:7e) swp2 - -
Verify the final configuration:
storage port showEach port should display enabled for
Stateand enabled forStatus.Show example
Show example
Verify that both nodes each have one connection to each switch:
net show lldpShow example
The following example shows the appropriate results for both switches:
cumulus@sw1:~$ net show lldp LocalPort Speed Mode RemoteHost RemotePort --------- ----- -------- --------------------- ----------- ... swp1 100G Trunk/L2 node1 e0c swp2 100G Trunk/L2 node2 e0c swp3 100G Trunk/L2 SHFFG1826000112 e0a swp4 100G Trunk/L2 SHFFG1826000112 e0a swp5 100G Trunk/L2 SHFFG1826000102 e0a swp6 100G Trunk/L2 SHFFG1826000102 e0a cumulus@sw2:~$ net show lldp LocalPort Speed Mode RemoteHost RemotePort --------- ----- -------- --------------------- ----------- ... swp1 100G Trunk/L2 node1 e5b swp2 100G Trunk/L2 node2 e5b swp3 100G Trunk/L2 SHFFG1826000112 e0b swp4 100G Trunk/L2 SHFFG1826000112 e0b swp5 100G Trunk/L2 SHFFG1826000102 e0b swp6 100G Trunk/L2 SHFFG1826000102 e0b
Step 3: Complete the procedure
Create a password for the Ethernet switch health monitor log collection feature:
system switch ethernet log setup-passwordShow example
cluster1::*> system switch ethernet log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: sw1 sw2 cluster1::*> system switch ethernet log setup-password Enter the switch name: sw1 Would you like to specify a user other than admin for log collection? {y|n}: n Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system switch ethernet log setup-password Enter the switch name: sw2 Would you like to specify a user other than admin for log collection? {y|n}: n Enter the password: <enter switch password> Enter the password again: <enter switch password> -
Enable the Ethernet switch health monitor log collection feature:
system switch ethernet log modify -device <switch-name> -log-request trueShow example
cluster1::*> system switch ethernet log modify -device cs1 -log-request true Do you want to modify the cluster switch log collection configuration? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*> system switch ethernet log modify -device cs2 -log-request true Do you want to modify the cluster switch log collection configuration? {y|n}: [n] y Enabling cluster switch log collection.Wait for 10 minutes and then check that the log collection completes:
system switch ethernet log showShow example
cluster1::*> system switch ethernet log show Log Collection Enabled: true Index Switch Log Timestamp Status ------ ---------------------------- ------------------- --------- 1 sw1 (b8:ce:f6:19:1b:42) 4/29/2022 03:05:25 complete 2 sw2 (b8:ce:f6:19:1b:96) 4/29/2022 03:07:42 complete
If any of these commands return an error or if the log collection does not complete, contact NetApp support. -
Change the privilege level back to admin:
set -privilege admin -
If you suppressed automatic case creation, reenable it by invoking an AutoSupport message:
