Learn about the ARL upgrade sequence
Contributors netapp-pcarriga netapp-aoife netapp-martyh
Before you upgrade the nodes using ARL, you should understand how the procedure works. In this content, the procedure is broken down into several stages.
Upgrade the node pair
To upgrade the node pair, you need to prepare the original nodes and then perform a series of steps on both the original and new nodes. You can then decommission the original nodes.
ARL upgrade sequence overview
During the procedure, you upgrade the original controller hardware with the replacement controller hardware, one controller at a time, taking advantage of the HA pair configuration to relocate the ownership of non-root aggregates. All non-root aggregates must undergo two relocations to reach their final destination, which is the correct upgraded node.
Each aggregate has a home owner and current owner. The home owner is the actual owner of the aggregate, and the current owner is the temporary owner.
The following table describes the high-level tasks you perform during each stage and the state of aggregate ownership at the end of the stage. Detailed steps are provided later in the procedure:
Stage Steps
Stage 1: Prepare for upgrade
During Stage 1, you verify that you have the correct hardware for your upgrade, run prechecks, and, if required, correct aggregate ownership. You must record certain information if you are managing Storage Encryption by using the Onboard Key Manager and you can choose to quiesce the SnapMirror relationships.
Aggregate ownership at the end of Stage 1:
  • Node1 is the home owner and current owner of the node1 aggregates
  • Node2 is the home owner and current owner of the node2 aggregates
Stage 2: Relocate resources and retire node1
During Stage 2, you relocate node1 non-root aggregates and NAS data LIFs from node1 to node2. This process is largely automated; the operation pauses to enable you to check its status. You must manually resume the operation. If required, you relocate failed or vetoed aggregates. You record node1 information for use later in the procedure before retiring node1. You can also prepare to netboot node1 later in the procedure.
Aggregate ownership at the end of Stage 2:
  • Node2 is the current owner of node1 aggregates
  • Node2 is the home owner and current owner of node2 aggregates
Stage 3: Boot node1 with the replacement system modules
During Stage 3, you boot node1 with upgraded system modules and verify the upgraded node1 installation. If you are using NetApp Volume Encryption (NVE), you restore key-manager configuration. You also relocate node1 non-root aggregates and NAS data LIFs from node2 to the upgraded node1 and verify that the SAN LIFs exist on node1.
Aggregate ownership at the end of Stage 3:
  • Upgraded node1 is the home owner and current owner of node1 aggregates
Stage 4: Relocate resources and retire node2
During Stage 4, you relocate non-root aggregates and NAS data LIFs from node2 to the upgraded node1 and retire node2.
Aggregate ownership at the end of Stage 4:
  • Upgraded node1 is the home owner and current owner of aggregates that originally belonged to node1
  • Upgraded node1 is the current owner of node2 aggregates
Stage 5: Install the replacement system modules on node2
During Stage 5, you install the new system modules that you received for the upgraded node2 and then netboot node2.
Aggregate ownership at the end of Stage 5:
  • Upgraded node1 is the home owner and current owner of the aggregates that originally belonged to node1.
  • Upgraded node2 is the home owner and current owner of aggregates that originally belonged to node2.
Stage 6: Boot node2 with the replacement system modules
During Stage 6, you boot node2 with upgraded system modules and verify the upgraded node2 installation. If you are using NVE, you restore key-manager configuration. For switch-attached cluster upgrades, you need to validate that the cluster switch reference configuration file (RCF) supports the shared cluster/HA ports. You also relocate node1 non-root aggregates and NAS data LIFs from node1 to the upgraded node2 and verify that the SAN LIFs exist on node2.
Stage 7: Complete the upgrade
During Stage 7, you confirm that the new nodes are set up correctly and, if the new nodes are encryption-enabled, you configure and set up Storage Encryption or NVE. You should also decommission the old nodes and resume the SnapMirror operations.
