Stage 3 overview
PDF of this doc site
Upgrade by using ARL
Use "system controller replace" commands to upgrade controller models in the same chassis
Creating your file...
Your file is ready
During Stage 3, you install and boot node3, check that the cluster and node-management ports from node1 come online on node3, and verify the node3 installation. If you are using NetApp Volume Encryption (NVE), you restore key-manager configuration. You also relocate the node1 NAS data LIFs and non-root aggregates from node2 to node3 and verify that the SAN LIFs exist on node3.
