Install and boot node3
Contributors netapp-pcarriga netapp-aoife netapp-aherbin
You must install node3 in the rack, transfer node1's connections to node3, boot node3, and install ONTAP. You must then reassign any of node1's spare disks, any disks belonging to the root volume, and any non-root aggregates that were not relocated to node2 earlier in the process, as outlined in this section.
About this task
The relocation operation is paused at the beginning of this stage. This process is largely automated; the operation pauses to enable you to check its status. You must manually resume the operation. In addition, you must verify the SAN LIFs have successfully moved to node3.
You need to netboot node3 if it does not have the same version of ONTAP 9 that is installed on node1. After you install node3, boot it from the ONTAP 9 image stored on the web server. You can then download the correct files to the boot media device for subsequent system boots, by following the instructions in Prepare for netboot.
Important
Steps
  1. Make sure that you have rack space for node3.
    If node1 and node2 were in separate chassis, you can put node3 in the same rack location as node1. However, if node1 was in the same chassis with node2, then you need to put node3 into its own rack space, preferably close to the location of node1.
  2. Install node3 in the rack, following the Installation and Setup Instructions for your node model.
    Note If you're upgrading to a system with both nodes in the same chassis, install node4 and node3 in the chassis. If you don't install both nodes in the same chassis, when you boot node3, it behaves as if it were in a dual-chassis configuration, and when you boot node4, the interconnect between the nodes doesn't come up.
  3. Cable node3, moving the connections from node1 to node3.
    Cable the following connections using the Installation and Setup Instructions for the node3 platform, the appropriate disk shelf document, and the HA pair management documentation.
    Refer to References to link to HA pair management.
    • Console (remote management port)
    • Cluster ports
    • Data ports
    • Cluster and node management ports
    • Storage
    • SAN configurations: iSCSI Ethernet and FC switch ports
      Note You might not need to move the interconnect card or the cluster interconnect cable connection from node1 to node3 because most platform models have a unique interconnect card model.
      For the MetroCluster configuration, you need to move the FC-VI cable connections from node1 to node3. If the new host does not have an FC-VI card, you might need to move the FC-VI card.
  4. Turn on the power to node3, and then interrupt the boot process by pressing Ctrl-C at the console terminal to access the boot environment prompt.
    If you are upgrading to a system with both nodes in the same chassis, node4 also reboots. However, you can disregard the node4 boot until later.
    Note When you boot node3, you might see the following warning message:
    WARNING: The battery is unfit to retain data during a power outage. This is likely because the battery is discharged but could be due to other temporary conditions.
    When the battery is ready, the boot process will complete and services will be engaged.
    To override this delay, press 'c' followed by 'Enter'
  5. If you see the warning message in Step 4, take the following actions:
    1. Check for any console messages that might indicate a problem other than a low NVRAM battery, and, if necessary, take any required corrective action.
    2. Allow the battery to charge and the boot process to complete.
      Warning Do not override the delay; failure to allow the battery to charge could result in a loss of data.
  1. Configure the netboot connection by choosing one of the following actions.
    Note You must use the management port and IP as the netboot connection. Do not use a data LIF IP or a data outage might occur while the upgrade is being performed.
    If Dynamic Host Configuration Protocol (DHCP) is…​ Then…​
    Running
    Configure the connection automatically by entering the following command at the boot environment prompt:
    ifconfig e0M -auto
    Not running
    Manually configure the connection by entering the following command at the boot environment prompt:
    ifconfig e0M -addr=filer_addr -mask=netmask -gw=gateway -dns=dns_addr -domain=dns_domain
    filer_addr is the IP address of the storage system (mandatory).
    netmask is the network mask of the storage system (mandatory).
    gateway is the gateway for the storage system. (mandatory).
    dns_addr is the IP address of a name server on your network (optional).
    dns_domain is the Domain Name Service (DNS) domain name. If you use this optional parameter, you do not need a fully qualified domain name in the netboot server URL; you need only the server's host name.
    Note Other parameters might be necessary for your interface. Enter help ifconfig at the firmware prompt for details.
  2. Perform netboot on node3:
    For…​ Then…​
    FAS/AFF8000 series systems
    netboot http://<web_server_ip/path_to_web-accessible_directory>/netboot/kernel
    All other systems
    netboot http://<web_server_ip/path_to_web-accessible_directory>/<ontap_version>_image.tgz
    The <path_to_the_web-accessible_directory> should lead to where you downloaded the <ontap_version>_image.tgz in the section Prepare for netboot.
    Note Do not interrupt the boot.
  3. From the boot menu, select option (7) Install new software first.
    This menu option downloads and installs the new ONTAP image to the boot device.
    Disregard the following message:
    This procedure is not supported for Non-Disruptive Upgrade on an HA pair
    The note applies to nondisruptive upgrades of ONTAP, and not upgrades of controllers.
    Note Always use netboot to update the new node to the desired image. If you use another method to install the image on the new controller, the incorrect image might install. This issue applies to all ONTAP releases. The netboot procedure combined with option (7) Install new software wipes the boot media and places the same ONTAP version on both image partitions.
  4. If you are prompted to continue the procedure, enter y, and when prompted for the package, enter the URL:
  5. Complete the following substeps to reboot the controller module:
    1. Enter n to skip the backup recovery when you see the following prompt:
      Do you want to restore the backup configuration now? {y|n}
    2. Enter y to reboot when you see the following prompt:
      The node must be rebooted to start using the newly installed software. Do you want to reboot now? {y|n}
      The controller module reboots but stops at the boot menu because the boot device was reformatted, and the configuration data must be restored.
  6. Select maintenance mode 5 from the boot menu and enter y when you are prompted to continue with the boot.
  7. Verify that the controller and chassis are configured as ha:
    ha-config show
    The following example shows the output of the ha-config show command:
    Chassis HA configuration: ha
    Controller HA configuration: ha
    Note System records in a PROM whether they are in an HA pair or stand-alone configuration. The state must be the same on all components within the stand-alone system or HA pair.
  8. If the controller and chassis are not configured as ha, use the following commands to correct the configuration:
    ha-config modify controller ha
    ha-config modify chassis ha
    If you have a MetroCluster configuration, use the following commands to modify the controller and chassis:
    ha-config modify controller mcc
    ha-config modify chassis mcc
  9. Exit maintenance mode:
    halt
    Interrupt AUTOBOOT by pressing Ctrl-C at the boot environment prompt.
  10. On node2, check the system date, time, and time zone:
    date
  11. On node3, check the date by using the following command at the boot environment prompt:
    show date
  12. If necessary, set the date on node3:
    set date mm/dd/yyyy
  13. On node3, check the time by using the following command at the boot environment prompt:
    show time
  14. If necessary, set the time on node3:
    set time hh:mm:ss
  15. In boot loader, set the partner system ID on node3:
    setenv partner-sysid node2_sysid
    For node3, partner-sysid must be that of node2.
    1. Save the settings:
      saveenv
  16. Verify the partner-sysid for node3:
    printenv partner-sysid
  1. If you have NetApp Storage Encryption (NSE) drives installed, perform the following steps.
    Note If you have not already done so earlier in the procedure, see the Knowledge Base article How to tell if a drive is FIPS certified to determine the type of self-encrypting drives that are in use.
    1. Set bootarg.storageencryption.support to true or false:
      If the following drives are in use… Then…
      NSE drives that conform to FIPS 140-2 Level 2 self-encryption requirements
      setenv bootarg.storageencryption.support true
      NetApp non-FIPS SEDs
      setenv bootarg.storageencryption.support false
      Note
      You cannot mix FIPS drives with other types of drives on the same node or HA pair.
      You can mix SEDs with non-encrypting drives on the same node or HA pair.
    2. Contact NetApp Support for assistance with restoring the onboard key management information.
  2. Boot the node into boot menu:
    boot_ontap menu
What's next?
