Set the FC or UTA/UTA2 configuration on node4
If node4 has onboard FC ports, onboard unified target adapter (UTA/UTA2) ports, or a UTA/UTA2 card, you must configure the settings before completing the rest of the procedure.
You might need to complete Configure FC ports on node4, or Check and configure UTA/UTA2 ports on node4, or both sections.
If node4 doesn't have onboard FC ports, onboard UTA/UTA2 ports, or a UTA/UTA2 card, and you are upgrading a system with storage disks, you can skip to Reassign node2 disks to node4. Make sure that node4 has sufficient rack space. If node4 is in a separate chassis from node2, you can put node4 in the same location as node3. If node2 and node4 are in the same chassis, then node4 is already in its appropriate rack location. |
Step 1: Configure FC ports on node4
If node4 has FC ports, either onboard or on an add-on FC adapter, you must set port configurations on the node before you bring it into service because the ports are not preconfigured when the systems are shipped. If you don't configure the ports as required, you might experience a disruption in service.
You must have the values of the FC port settings from node2 that you saved in the section Prepare the nodes for upgrade.
You can skip this section if your system does not have FC configurations. If your system has onboard UTA/UTA2 ports or a UTA/UTA2 adapter, you configure them in Check and configure UTA/UTA2 ports on node4.
Enter the commands in this section at the Maintenance mode shell prompt. |
Display information about all FC and converged network adapters on the system:
system node hardware unified-connect show -
Compare the FC settings on node4 with the settings that you captured earlier from node1.
Modify the FC ports on node4 as needed:
To program as target ports:
ucadmin modify -m fc -t target adapterFor example:
ucadmin modify -m fc -t target 2a -
To program initiator ports:
ucadmin modify -m fc -t initiator adapter-tis the FC4 type: target or initiator.For example:
ucadmin modify -m fc -t initator 2b
Halt the node:
halt -
Boot the system from LOADER prompt:
boot_ontap menu -
After you enter the command, wait until the system stops at the boot environment prompt.
Select option
5from the boot menu for maintenance mode.
Take one of the following actions:
Go to Check and configure UTA/UTA2 ports on node4 if node4 has a UTA/UTA2 card or UTA/UTA2 onboard ports.
If node4 doesn't have a UTA/UTA2 card or UTA/UTA2 onboard ports, skip Check and configure UTA/UTA2 ports on node4 and go to Reassign node2 disks to node4.
Step 2: Check and configure UTA/UTA2 ports on node4
If node4 has onboard UTA/UTA2 ports or a UTA/UTA2A card, you must check the configuration of the ports and configure them, depending on how you want to use the upgraded system.
You must have the correct SFP+ modules for the UTA/UTA2 ports.
UTA/UTA2 ports can be configured into native FC mode or UTA/UTA2A mode. FC mode supports FC initiator and FC target; UTA/UTA2 mode allows concurrent NIC and FCoE traffic to share the same 10GbE SFP+ interface and supports FC target.
NetApp marketing materials might use the term UTA2 to refer to CNA adapters and ports. However, the CLI uses the term CNA. |
UTA/UTA2 ports might be on an adapter or on the controller with the following configurations:
UTA/UTA2 cards ordered at the same time as the controller are configured before shipment to have the personality you requested.
UTA/UTA2 cards ordered separately from the controller are shipped with the default FC target personality.
Onboard UTA/UTA2 ports on new controllers are configured (before shipment) to have the personality you requested.
However, you should check the configuration of the UTA/UTA2 ports on node4 and change it, if necessary.
Check how the ports are currently configured on node4:
system node hardware unified-connect showThe system displays output similar to the following example:
*> ucadmin show Current Current Pending Pending Admin Node Adapter Mode Type Mode Type Status ---- ------- --- --------- ------- -------- ------- f-a 0e fc initiator - - online f-a 0f fc initiator - - online f-a 0g cna target - - online f-a 0h cna target - - online f-a 0e fc initiator - - online f-a 0f fc initiator - - online f-a 0g cna target - - online f-a 0h cna target - - online *> -
If the current SFP+ module does not match the desired use, replace it with the correct SFP+ module.
Contact your NetApp representative to obtain the correct SFP+ module.
Verify the settings:
ucadmin showExamine the output of the
ucadmin showcommand and determine whether the UTA/UTA2 ports have the personality you want.The output in the following examples shows that the FC4 type of adapter "1b" is changing to
initiatorand that the mode of adapters "2a" and "2b" is changing tocna:*> ucadmin show Node Adapter Current Mode Current Type Pending Mode Pending Type Admin Status ---- ------- ------------ ------------ ------------ ------------ ------------ f-a 1a fc initiator - - online f-a 1b fc target - initiator online f-a 2a fc target cna - online f-a 2b fc target cna - online 4 entries were displayed. *>
If the CNA ports… Then… Do not have the personality that you want
Go to Step 5.
Have the personality that you want
Skip Step 5 through Step 9 and go to Step 10.
If you are configuring… Then… Ports on a UTA/UTA2 card
Go to Step 6
Skip Step 6 and go to Step 7.
If the adapter is in initiator mode, and if the UTA/UTA2 port is online, take the UTA/UTA2 port offline:
storage disable adapter adapter_nameAdapters in target mode are automatically offline in Maintenance mode.
If the current configuration does not match the desired use, change the configuration as needed:
ucadmin modify -m fc|cna -t initiator|target <adapter_name>-
-mis the personality mode, FC or 10GbE UTA. -
-tis the FC4 type,targetorinitiator.You must use FC initiator for tape drives and MetroCluster configurations. You must use the FC target for SAN clients.
Place any target ports online by entering the following command, once for each port:
storage enable adapter <adapter_name> -
Cable the port.
If you are upgrading to an AFF A800 system, go to Reassign node2 disks to node4, Step 9.
For all other system upgrades, go to Reassign node2 disks to node4, Step 1.
