Install and boot node4
You must install node4 in the rack, transfer the node2 connections to to node4, boot node4, and install ONTAP. You must then reassign any spare disks on node2, any disks belonging to the root volume, and any non-root aggregates that were not relocated to node3 earlier in the process, as outlined in this section.
The relocation operation is paused at the beginning of this stage. This process is mostly automated; the operation pauses to enable you to check its status. You must manually resume the operation. In addition, you must verify that the NAS data LIFs have successfully moved to node4.
You need to netboot node4 if the ONTAP version on node4 is different to the ONTAP version on node2. After you install node4, boot it from the ONTAP 9 image stored on the web server. You can then download the correct files to the boot media device for subsequent system boots by following the instructions in Prepare for netboot.
Make sure that node4 has sufficient rack space.
If node4 is in a separate chassis from node2, you can put node4 in the same location as node3. If node2 and node4 are in the same chassis, then node4 is already in its appropriate rack location.
Install node4 in the rack, following the instructions in the Installation and Setup Instructions for the node model.
Cable node4, moving the connections from node2 to node4.
Cable the following connections, using the Installation and Setup Instructions for the node4 platform, the appropriate disk shelf document, and the HA pair management documentation.
Refer to References to link to HA pair management.
Console (remote management port)
Cluster ports
Data ports
Cluster and node management ports
Storage
SAN configurations: iSCSI Ethernet and FC switch ports
You might not need to move the interconnect card/FC-VI card or interconnect/FC-VI cable connection from node2 to node4 because most platform models have unique interconnect card models.
For the MetroCluster configuration, you must move the FC-VI cable connections from node2 to node4. If the new host does not have an FC-VI card, you might need to move the FC-VI card.
Turn on the power to node4, and then interrupt the boot process by pressing Ctrl-C at the console terminal to access the boot environment prompt.
When you boot node4, you might see the following warning message: WARNING: The battery is unfit to retain data during a power outage. This is likely because the battery is discharged but could be due to other temporary conditions. When the battery is ready, the boot process will complete and services will be engaged. To override this delay, press 'c' followed by 'Enter' -
If you see the warning message in Step 4, take the following actions:
Check for any console messages that might indicate a problem other than a low NVRAM battery, and, if necessary, take any required corrective action.
Allow the battery to charge and the boot process to complete.
Do not override the delay; failure to allow the battery to charge could result in a loss of data. Refer to Prepare for netboot.
Configure the netboot connection by choosing one of the following actions.
You must use the management port and IP as the netboot connection. Do not use a data LIF IP or a data outage might occur while the upgrade is being performed. If Dynamic Host Configuration Protocol (DHCP) is… Then… Running
Configure the connection automatically by entering the following command at the boot environment prompt:
ifconfig e0M -autoNot running
Manually configure the connection by entering the following command at the boot environment prompt:
ifconfig e0M -addr=filer_addr -mask=netmask -gw=gateway -dns=dns_addr -domain=dns_domain
filer_addris the IP address of the storage system (mandatory).
netmaskis the network mask of the storage system (mandatory).
gatewayis the gateway for the storage system (mandatory).
dns_addris the IP address of a name server on your network (optional).
dns_domainis the Domain Name Service (DNS) domain name. If you use this optional parameter, you do not need a fully qualified domain name in the netboot server URL; you need only the server's host name.
NOTE: Other parameters might be necessary for your interface. Enterhelp ifconfigat the firmware prompt for details. -
Perform netboot on node4:
For… Then… FAS/AFF8000 series systems
netboot http://<web_server_ip/path_to_web-accessible_directory>/netboot/kernelAll other systems
netboot http://<web_server_ip/path_to_web-accessible_directory>/<ontap_version>_image.tgzThe
<path_to_the_web-accessible_directory>should lead to where you downloaded the<ontap_version>_image.tgzin Step 1 in the section Prepare for netboot.Do not interrupt the boot. -
From the boot menu, select option
(7) Install new software first.This menu option downloads and installs the new ONTAP image to the boot device.
Disregard the following message:
This procedure is not supported for Non-Disruptive Upgrade on an HA pairThe note applies to nondisruptive upgrades of ONTAP, and not upgrades of controllers.
Always use netboot to update the new node to the desired image. If you use another method to install the image on the new controller, the incorrect image might install. This issue applies to all ONTAP releases. The netboot procedure combined with option (7) Install new softwarewipes the boot media and places the same ONTAP version on both image partitions. -
If you are prompted to continue the procedure, enter
y, and when prompted for the package, enter the URL:http://<web_server_ip/path_to_web-accessible_directory>/<ontap_version>_image.tgz -
Complete the following substeps to reboot the controller module:
Enter
nto skip the backup recovery when you see the following prompt:Do you want to restore the backup configuration now? {y|n} -
Reboot by entering
ywhen you see the following prompt:The node must be rebooted to start using the newly installed software. Do you want to reboot now? {y|n}The controller module reboots but stops at the boot menu because the boot device was reformatted, and the configuration data must be restored.
Select maintenance mode
5from the boot menu and enterywhen you are prompted to continue with the boot. -
Verify that the controller and chassis are configured as HA:
ha-config showThe following example shows the output of the
ha-config showcommand:Chassis HA configuration: ha Controller HA configuration: ha
System records in a PROM whether they are in an HA pair or stand-alone configuration. The state must be the same on all components within the stand-alone system or HA pair. -
If the controller and chassis are not configured as HA, use the following commands to correct the configuration:
ha-config modify controller haha-config modify chassis haIf you have a MetroCluster configuration, use the following commands to modify the controller and chassis:
ha-config modify controller mccha-config modify chassis mcc -
Exit maintenance mode:
haltInterrupt AUTOBOOT by pressing Ctrl-C at the boot environment prompt.
On node3, check the system date, time, and time zone:
date -
On node4, check the date by using the following command at the boot environment prompt:
show date -
If necessary, set the date on node4:
set date mm/dd/yyyy -
On node4, check the time by using the following command at the boot environment prompt:
show time -
If necessary, set the time on node4:
set time hh:mm:ss -
In boot loader, set the partner system ID on node4:
setenv partner-sysid node3_sysidFor node4,
partner-sysidmust be that of node3.Save the settings:
saveenv -
Verify the
partner-sysidfor node4:printenv partner-sysid
If you have NetApp Storage Encryption (NSE) drives installed, perform the following steps:
If you have not already done so earlier in the procedure, see the Knowledge Base article How to tell if a drive is FIPS certified to determine the type of self-encrypting drives that are in use. -
Set
bootarg.storageencryption.supporttotrueorfalse:If the following drives are in use… Then… NSE drives that conform to FIPS 140-2 Level 2 self-encryption requirements
setenv bootarg.storageencryption.support trueNetApp non-FIPS SEDs
setenv bootarg.storageencryption.support falseYou cannot mix FIPS drives with other types of drives on the same node or HA pair.
You can mix SEDs with non-encrypting drives on the same node or HA pair. -
Contact NetApp Support for assistance with restoring the onboard key management information.
Boot the node into boot menu:
boot_ontap menu
If you have a system with an FC or UTA/UTA2 configuration, set the FC or UTA/UTA2 configuration on node4.
If you don't have an FC or UTA/UTA2 configuration, reassign node2 disks to node4, Step 1 so that node4 can recognize node2’s disks.
If you have a MetroCluster configuration, set the FC or UTA/UTA2 configuration on node4 to detect the disks attached to the node.
