Confirm that the new controllers are set up correctly
To confirm correct setup, you enable the HA pair. You also verify that node3 and node4 can access each other's storage and that neither owns data LIFs belonging to other nodes on the cluster. In addition, you confirm that node3 owns node1's aggregates and that node4 owns node2's aggregates, and that the volumes for both nodes are online.
Enable storage failover by entering the following command on one of the nodes:
storage failover modify -enabled true -node <node3> -
Verify that storage failover is enabled:
storage failover showThe following example shows the output of the command when storage failover is enabled:
cluster::> storage failover show Takeover Node Partner Possible State Description -------------- -------------- -------- ------------------ node3 node4 true Connected to node4 node4 node3 true Connected to node3 -
Take one of the following actions:
If the cluster is a… Description Two-node cluster
Enable cluster high availability by entering the following command on either node:
cluster ha modify -configured trueCluster with more than two nodes
Go to Step 4.
Verify that node3 and node4 belong to the same cluster by entering the following command and examining the output:
cluster show -
Verify that node3 and node4 can access each other's storage by entering the following command and examining the output:
storage failover show -fields local-missing-disks,partner-missing-disks -
Verify that neither node3 nor node4 owns data LIFs home-owned by other nodes in the cluster by entering the following command and examining the output:
network interface showIf either node3 or node4 owns data LIFs home-owned by other nodes in the cluster, use the
network interface revertcommand to revert the data LIFs to their home-owner. -
Verify that node3 owns the aggregates from node1 and that node4 owns the aggregates from node2:
storage aggregate show -owner-name <node3>
storage aggregate show -owner-name <node4> -
Determine whether any volumes are offline:
volume show -node <node3> -state offline
volume show -node <node4> -state offline -
If any volumes are offline, compare them with the list of offline volumes that you captured in Step 19 (d) in Prepare the nodes for upgrade, and bring online any of the offline volumes, as required, by entering the following command, once for each volume:
volume online -vserver <vserver_name> -volume <volume_name> -
Install new licenses for the new nodes by entering the following command for each node:
system license add -license-code <license_code,license_code,license_code…>The license-code parameter accepts a list of 28 upper-case alphabetic character keys. You can add one license at a time, or you can add multiple licenses at once, each license key separated by a comma.
If self-encrypting drives are being used in the configuration and you have set the
kmip.init.maxwaitvariable tooff(for example, in Step 16 of Install and boot node3), you must unset the variable:set diag; systemshell -node node_name -command sudo kenv -u -p kmip.init.maxwait -
To remove all of the old licenses from the original nodes, enter one of the following commands:
system license clean-up -unused -expired
system license delete -serial-number <node_serial_number> -package <licensable_package>-
To delete all expired licenses, enter:
system license clean-up -expired -
To delete all unused licenses, enter:
To delete a specific license from a cluster, enter the following commands on the nodes:
system license delete -serial-number <node1_serial_number> -package *
system license delete -serial-number <node2_serial_number> -package *The following output is displayed:
Warning: The following licenses will be removed: <list of each installed package> Do you want to continue? {y|n}: yEnter
yto remove all of the packages.
Verify that the licenses are correctly installed by entering the following command and examining its output:
system license showYou can compare the output with the output that you captured in Step 29 of Prepare the nodes for upgrade.
Configure the SPs by performing the following command on both nodes:
system service-processor network modify -node <node_name>Go to References to link to the System Administration Reference for information about the SPs and the ONTAP 9 Command reference for detailed information about the
system service- processor network modifycommand. -
If you want to set up a switchless cluster on the new nodes, go to References to link to the Network Support Site and follow the instructions in Transitioning to a two-node switchless cluster.
If Storage Encryption is enabled on node3 and node4, complete the steps in Set up Storage Encryption on the new controller module. Otherwise, complete the steps in Decommission the old system.
