Move NAS data LIFs owned by node2 from node3 to node4 and verify SAN LIFs on node4
After you verify the node4 installation and before you relocate node2 aggregates from node3 to node4, you must move the NAS data LIFs owned by node2 currently on node3 from node3 to node4. You also need to verify the SAN LIFs on node4.
Remote LIFs handle traffic to SAN LUNs during the upgrade procedure. Moving SAN LIFs is not necessary for cluster or service health during the upgrade. SAN LIFs are not moved unless they need to be mapped to new ports. You verify that the LIFs are healthy and located on appropriate ports after you bring node4 online.
List all the NAS data LIFs that are not owned by node3 by entering the following command on either node and capturing the output:
network interface show -role data -curr-node node3 -is-home false -
If the cluster is configured for SAN LIFs, record the SAN LIFs and existing configuration information in this worksheet for use later in the procedure.
List the SAN LIFs on node3 and examine the output:
network interface show -data-protocol fc*The system returns output similar to the following example:
cluster1::> net int show -data-protocol fc* (network interface show) Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- svm2_cluster1 lif_svm2_cluster1_340 up/up 20:02:00:50:56:b0:39:99 cluster1-01 1b true lif_svm2_cluster1_398 up/up 20:03:00:50:56:b0:39:99 cluster1-02 1a true lif_svm2_cluster1_691 up/up 20:01:00:50:56:b0:39:99 cluster1-01 1a true lif_svm2_cluster1_925 up/up 20:04:00:50:56:b0:39:99 cluster1-02 1b true 4 entries were displayed. -
List the existing configurations and examine the output:
fcp adapter show -fields switch-port,fc-wwpnThe system returns output similar to the following example:
cluster1::> fcp adapter show -fields switch-port,fc-wwpn (network fcp adapter show) node adapter fc-wwpn switch-port ----------- ------- ----------------------- ------------- cluster1-01 0a 50:0a:09:82:9c:13:38:00 ACME Switch:0 cluster1-01 0b 50:0a:09:82:9c:13:38:01 ACME Switch:1 cluster1-01 0c 50:0a:09:82:9c:13:38:02 ACME Switch:2 cluster1-01 0d 50:0a:09:82:9c:13:38:03 ACME Switch:3 cluster1-01 0e 50:0a:09:82:9c:13:38:04 ACME Switch:4 cluster1-01 0f 50:0a:09:82:9c:13:38:05 ACME Switch:5 cluster1-01 1a 50:0a:09:82:9c:13:38:06 ACME Switch:6 cluster1-01 1b 50:0a:09:82:9c:13:38:07 ACME Switch:7 cluster1-02 0a 50:0a:09:82:9c:6c:36:00 ACME Switch:0 cluster1-02 0b 50:0a:09:82:9c:6c:36:01 ACME Switch:1 cluster1-02 0c 50:0a:09:82:9c:6c:36:02 ACME Switch:2 cluster1-02 0d 50:0a:09:82:9c:6c:36:03 ACME Switch:3 cluster1-02 0e 50:0a:09:82:9c:6c:36:04 ACME Switch:4 cluster1-02 0f 50:0a:09:82:9c:6c:36:05 ACME Switch:5 cluster1-02 1a 50:0a:09:82:9c:6c:36:06 ACME Switch:6 cluster1-02 1b 50:0a:09:82:9c:6c:36:07 ACME Switch:7 16 entries were displayed
Take one of the following actions:
If node2… Description Had interface groups or VLANs configured
Go to Step 4.
Did not have interface groups or VLANs configured
Skip Step 4 and go to Step 5.
Take the following steps to migrate any NAS data LIFs hosted on interface groups and VLANs that originally were on node2 from node3 to node4.
Migrate any LIFs hosted on node3 that previously belonging to node2 on an interface group to a port on node4 that is capable of hosting LIFs on the same network by entering the following command, once for each LIF:
network interface migrate -vserver vserver_name -lif lif_name -destination-node node4 –destination-port netport|ifgrp -
Modify the home port and home node of the LIFs in Substep a to the port and node currently hosting the LIFs by entering the following command, once for each LIF:
network interface modify -vserver vserver_name -lif datalif_name -home-node node4 home-port netport|ifgrp -
Migrate any LIFs hosted on node3 that previously belonged to node2 on a VLAN port to a port on node4 that is capable of hosting LIFs on the same network by entering the following command, once for each LIF:
network interface migrate -vserver vserver_name -lif datalif_name -destination-node node4 –destination-port netport|ifgrp -
Modify the home port and home node of the LIFs in Substep c to the port and node currently hosting the LIFs by entering the following command, once for each LIF:
If the cluster is configured for… Then… NAS
Complete Step 6 through Step 9, skip Step 10, and complete Step 11 through Step 14.
SAN
Skip Step 6 through Step 9, and complete Step 10 through Step 14.
Both NAS and SAN
If you have data ports that are not the same on your platforms, enter the following command to add the ports to the broadcast domain:
network port broadcast-domain add-ports -ipspace IPspace_name -broadcast-domain mgmt ports node:portThe following example adds port "e0a" on node "6280-1" and port "e0i" on node "8060-1" to broadcast domain mgmt in the IPspace Default:
cluster::> network port broadcast-domain add-ports -ipspace Default -broadcast-domain mgmt -ports 6280-1:e0a, 8060-1:e0i
Migrate each NAS data LIF to node4 by entering the following command, once for each LIF:
network interface migrate -vserver vserver-name -lif datalif-name -destination-node node4 -destination-port netport|ifgrp -home-node node4 -
Make sure that the data migration is persistent:
network interface modify -vserver vserver_name -lif datalif_name -home-port netport|ifgrp -
Verify the status of all links as
upby entering the following command to list all the network ports and examining its output:network port showThe following example shows the output of the
network port showcommand with some LIFs up and others down:cluster::> network port show Speed (Mbps) Node Port IPspace Broadcast Domain Link MTU Admin/Oper ------ --------- ------------ ---------------- ----- ------- ----------- node3 a0a Default - up 1500 auto/1000 e0M Default 172.17.178.19/24 up 1500 auto/100 e0a Default - up 1500 auto/1000 e0a-1 Default 172.17.178.19/24 up 1500 auto/1000 e0b Default - up 1500 auto/1000 e1a Cluster Cluster up 9000 auto/10000 e1b Cluster Cluster up 9000 auto/10000 node4 e0M Default 172.17.178.19/24 up 1500 auto/100 e0a Default 172.17.178.19/24 up 1500 auto/1000 e0b Default - up 1500 auto/1000 e1a Cluster Cluster up 9000 auto/10000 e1b Cluster Cluster up 9000 auto/10000 12 entries were displayed. -
If the output of the
network port showcommand displays network ports that are not available in the new node and are present in the old nodes, delete the old network ports by completing the following substeps:-
Enter the advanced privilege level by entering the following command:
set -privilege advanced -
Enter the following command, once for each old network port:
network port delete -node node_name -port port_name -
Return to the admin level by entering the following command:
set -privilege admin
Confirm that the SAN LIFs are on the correct ports on node4 by completing the following substeps:
Enter the following command and examine its output:
network interface show -data-protocol iscsi|fcp -home-node node4The system returns output similar to the following example:
cluster::> network interface show -data-protocol iscsi|fcp -home-node node4 Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- vs0 a0a up/down 10.63.0.53/24 node4 a0a true data1 up/up 10.63.0.50/18 node4 e0c true rads1 up/up 10.63.0.51/18 node4 e1a true rads2 up/down 10.63.0.52/24 node4 e1b true vs1 lif1 up/up 172.17.176.120/24 node4 e0c true lif2 up/up 172.17.176.121/24 node4 -
Verify that the new
adapterandswitch-portconfigurations are correct by comparing the output from thefcp adapter showcommand with the new configuration information that you recorded in the worksheet in Step 2.List the new SAN LIF configurations on node4:
If a SAN LIF in the new configuration is not on an adapter that is still attached to the same switch-port, it might cause a system outage when you reboot the node. -
If node4 has any SAN LIFs or groups of SAN LIFs that are on a port that did not exist on node2, move them to an appropriate port on node4 by entering one of the following commands:
Set the LIF status to down:
network interface modify -vserver vserver_name -lif lif_name -status-admin down -
Remove the LIF from the port set:
portset remove -vserver vserver_name -portset portset_name -port-name port_name -
Enter one of the following commands:
Move a single LIF:
network interface modify -lif lif_name -home-port new_home_port -
Move all the LIFs on a single nonexistent or incorrect port to a new port:
network interface modify {-home-port port_on_node2 -home-node node2 -role data} -home-port new_home_port_on_node4 -
Add the LIFs back to the port set:
portset add -vserver vserver_name -portset portset_name -port-name port_name
You must move SAN LIFs to a port that has the same link speed as the original port. -
Modify the status of all LIFs to
upso the LIFs can accept and send traffic on the node by entering the following command:network interface modify -vserver vserver_name -home-port port_name -home-node node4 lif lif_name -status-admin up -
Verify that any SAN LIFs have been moved to the correct ports and that the LIFs have the status of
upby entering the following command on either node and examining the output:network interface show -home-node node4 -role data -
If any LIFs are down, set the administrative status of the LIFs to
upby entering the following command, once for each LIF:network interface modify -vserver vserver_name -lif lif_name -status-admin up
