Replace the NV battery in an AFX 2K system
Replace the NV battery in your AFX 2K storage system when the battery begins to lose charge or fails, as it is responsible for preserving critical system data during power outages. The replacement process involves shutting down the impaired controller, removing the controller module, replacing the NV battery, reinstalling the controller module, and returning the failed part to NetApp.
This procedure applies to the replacement of a failed NV battery for the NVRAM module in slots 4 and 5 of the AFX 2K controller. For information on how to replace the NV battery for the NVRAM12-EX module in slots 6 and 7 of the AFX 2K controller, refer to Replace the NV battery for the NVRAM12-EX.
Step 1: Shut down the impaired controller
Shut down or take over the impaired controller.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
If you have a cluster with more than four nodes, it must be in quorum. To view cluster information about your nodes, use the
cluster showcommand. For more information about thecluster showcommand, see View node-level details in an ONTAP cluster. -
If the cluster is not in quorum or if the health or eligibility of any controller (other than the impaired controller) shows as false, you must correct the issue before shutting down the impaired controller. See Synchronize a node with the cluster.
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=<# of hours>hThe following AutoSupport message suppresses automatic case creation for two hours:
Disable automatic giveback from the console of the impaired controller:
storage failover modify -node impaired-node -auto-giveback-of falseWhen you see Do you want to disable auto-giveback?, enter y. -
Take the impaired controller to the LOADER prompt:
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
System prompt or password prompt
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name -halt trueThe -halt true parameter brings the impaired node to the LOADER prompt.
Step 2: Remove the controller module
You must remove the controller module from the enclosure when you replace the controller module or replace a component inside the controller module.
Check the NVRAM status LED located in slot 4/5 and the NVRAM12-EX status slot 6/7 of the system. There is also an NVRAM LED on the front panel of the controller module. Look for the NV icon:
NVRAM
NVRAM status LED
NVRAM attention LED
NVRAM12-EX
NVRAM12-EX status LED
NVRAM12-EX attention LED
If the NV LED is off, go to the next step.
If the NV LED is flashing, wait for the flashing to stop. If flashing continues for longer than 5 minutes, contact Technical Support for assistance.
If you are not already grounded, properly ground yourself.
Remove the bezel (if necessary) with two hands, by grasping the openings on each side of the bezel and pulling towards you until the bezel releases from the ball studs on the chassis frame.
On the front of the unit, hook your fingers into the holes in the locking cams, squeeze the tabs on the cam levers, and gently, but firmly rotate both latches toward you at the same time.
The controller module moves slightly out of the enclosure.
Locking cam latches
Slide the controller module out of the enclosure and place it on a flat, stable surface.
Make sure that you support the bottom of the controller module as you slide it out of the enclosure.
Step 3: Replace the NV battery
Remove the failed NV battery from the controller module and install the replacement NV battery.
Open the air duct cover and locate the NV battery.
NV battery air duct cover
NV battery plug
Lift the battery up to access the battery plug.
Squeeze the clip on the face of the battery plug to release the plug from the socket, and then unplug the battery cable from the socket.
Lift the battery out of the air duct and controller module, and then set it aside.
Remove the replacement battery from its package.
Install the replacement battery pack into the controller:
Plug the battery plug into the riser socket and make sure that the plug locks into place.
Insert the battery pack into the slot and press firmly down on the battery pack to make sure that it is locked into place.
Close the NV air duct cover.
Make sure that the plug locks into the socket.
Step 4: Reinstall the controller module
Reinstall the controller module and boot it.
Ensure the air duct is completely closed by rotating it down as far as it will go.
It must lie flush against the controller module sheet metal.
Align the end of the controller module with the opening in the enclosure, and slide the controller module into the chassis with the levers rotated away from the front of the system.
Once the controller module stops you from sliding it farther, rotate the cam handles inward until they latch back under the fans
Do not use excessive force when sliding the controller module into the enclosure to avoid damaging the connectors. The controller module begins to boot as soon as it is fully seated in the enclosure.
Align the bezel with the ball studs and then gently push the bezel into place.
Press <enter> when console messages stop.
If you see the login prompt, go to the next step.
If you do not see a login prompt, log into the partner node.
Give back only the root with override-destination-checks option:
storage failover giveback -ofnode impaired-node -only-root true -override -destination-checks trueThe following command is only available in the Diagnostic mode privilege level. For more information on privilege levels, see Understand the privilege levels for ONTAP CLI commands. If you encounter errors, contact NetApp Support.
Wait 5 minutes after the giveback report completes, then check failover and giveback status:
storage failover showandstorage failover show-givebackThe following command is only available in the Diagnostic mode privilege level. -
If automatic giveback was disabled, reenable it:
storage failover modify -node local -auto-giveback-of true -
Return the impaired controller to normal operation by giving back its storage:
storage failover giveback -ofnode impaired_node_name -
If AutoSupport is enabled, restore/unsuppress automatic case creation:
Step 5: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
