How vCenter Server RBAC works with ONTAP tools for VMware vSphere
ONTAP tools for VMware vSphere implements role-based access control (RBAC) with vCenter Server to control access to vSphere objects and administrative tasks. Understanding the RBAC model — including predefined roles, permission assignments, and how vCenter and ONTAP privileges interact — helps you configure appropriate access before deploying ONTAP tools in a production environment.
vCenter roles and the administrator account
You only need to define and use the custom vCenter Server roles if you want to limit access to the vSphere objects and associated administrative tasks. If limiting access is not required, you can use an administrator account instead. Each administrator account is defined with the Administrator role at the top level of the object hierarchy. This provides full access to the vSphere objects, including those added by ONTAP tools for VMware vSphere 10.
vSphere object hierarchy
The vSphere object inventory is organized in a hierarchy. For example, you can move down the hierarchy as follows:
vCenter Server -→ Datacenter -→ Cluster -→ ESXi host -→ Virtual Machine
All permissions are validated in the vSphere object hierarchy except the VAAI plug-in operations, which are validated against the target ESXi host.
Roles included with ONTAP tools for VMware vSphere 10
To simplify working with vCenter Server RBAC, ONTAP tools for VMware vSphere provides predefined roles tailored to various administrative tasks.
You can create new custom roles if needed. To do so, clone one of the existing ONTAP tools roles and edit it as needed. After making the configuration changes, the affected vSphere client users need to log out and log back in to activate the changes. |
To view the ONTAP tools for VMware vSphere roles, select Menu at the top of the vSphere Client, select Administration, and then select Roles on the left.
The following privileges must be included in the role assigned to the vCenter user responsible for deploying or onboarding vCenter Server. Verify that these privileges are configured before starting the deployment or onboarding process.
Alarms
Acknowledge alarm
Content Library
Add library item
Check in a template
Check out a template
Download files
Import storage
Read storage
Sync library item
Sync subscribed library
View configuration settings
Datastore
Allocate space
Browse datastore
Low level file operations
Remove file
Update virtual machine files
Update virtual machine metadata
ESX Agent Manager
View
Folder
Create folder
Host
Configuration
Advanced settings
Change settings
Network configuration
System resources
Virtual machine autostart configuration
Local operations
Create virtual machine
Delete virtual machine
Reconfigure virtual machine
Network
Assign network
Configure
OvfManager
OvfConsumer Access
Host profile
View
Resource
Assign virtual machine to resource pool
Scheduled task
Create tasks
Modify task
Run task
Tasks
Create task
Update task
vApp
Add virtual machine
Assign resource pool
Assign vApp
Create
Import
Move
Power off
Power on
Pull from URL
View OVF environment
Virtual machine
Change Configuration
Add existing disk
Add new disk
Add or remove device
Advanced configuration
Change CPU count
Change Memory
Change Settings
Change resource
Extend virtual disk
Modify device settings
Remove disk
Reset guest information
Upgrade virtual machine compatibility
Edit Inventory
Create from existing
Create new
Move
Register
Remove
Unregister
Interaction
Backup operation on virtual machine
Configure CD media
Configure floppy media
Connect devices
Console interaction
Guest operating system management by VIX API
Power off
Power on
Reset
Suspend
Provisioning
Allow disk access
Clone template
Customize guest
Deploy template
Modify customization specification
Read customization specifications
Snapshot management
Create snapshot
Remove snapshot
Rename snapshot
Revert to snapshot
ONTAP tools for VMware vSphere includes three predefined roles.
Provides all the native vCenter Server privileges and ONTAP tools-specific privileges required to perform core ONTAP tools for VMware vSphere administrator tasks.
Provides read-only access to ONTAP tools. These users cannot perform any ONTAP tools for VMware vSphere actions that are access-controlled.
Provides some of the native vCenter Server privileges and ONTAP tools-specific privileges that are required to provision storage. You can perform the following tasks:
Create new datastores
Manage datastores
vSphere objects and ONTAP storage backends
The two RBAC environments work together. When you perform a task in the vSphere Client, ONTAP tools checks the vCenter Server roles first. If the operation is permitted by vSphere, then the ONTAP role privileges are examined. This second step is performed based on the ONTAP role assigned to the user when the storage backend was created and configured.
Working with vCenter Server RBAC
Keep the following in mind when working with vCenter Server privileges and permissions.
Required privileges
To access the ONTAP tools for VMware vSphere 10 user interface, you need to have the ONTAP tools-specific View privilege. If you sign in to vSphere without this privilege and select the NetApp icon, ONTAP tools for VMware vSphere displays an error message and prevents you from accessing the user interface.
The assignment level in the vSphere object hierarchy determines which portions of the user interface you can access. Assigning the View privilege to the root object enables you to access ONTAP tools for VMware vSphere by clicking the NetApp icon.
You can instead assign the View privilege to another lower vSphere object level. However, this limits the ONTAP tools for VMware vSphere menus that you can access.
Assigning permissions
You need to use vCenter Server permissions if you want to limit access to the vSphere objects and tasks. Where you assign permission in the vSphere object hierarchy determines the ONTAP tools for VMware vSphere 10 tasks users can perform.
Unless you need to define more restrictive access, it's generally a good practice to assign permissions at the root object or root folder level. |
The permissions available with ONTAP tools for VMware vSphere 10 apply to custom non-vSphere objects, such as storage systems. If possible, you should assign these permissions to ONTAP tools for VMware vSphere root object because there is no vSphere object you can assign it to. For example, any permission that includes an ONTAP tools for VMware vSphere "Add/Modify/Remove storage systems" privilege should be assigned at the root object level.
When defining a permission at a higher level in the object hierarchy, you can configure the permission so it is passed down and inherited by the child objects. If needed, you can assign additional permissions to the child objects that override the permissions inherited from the parent.
You can modify a permission at any time. If you change any of the privileges within a permission, users associated with the permission need to log out of vSphere and log back in to enable the change.
