ONTAP tools for VMware vSphere 10
Configure high availability for ONTAP tools
The ONTAP tools supports a high-availability (HA) configuration to help provide uninterrupted functionality of ONTAP tools during failure.
The ONTAP tools relies on the VMware vSphere High-availability (HA) feature and vSphere fault tolerance (FT) feature to provide high availability. High-availability (HA) solution provides for rapid recovery from outages caused by:
  • Host failure
    Note Only single node failure is supported.
  • Network failure
  • Virtual machine failure (Guest OS failure)
  • Application (ONTAP tools) crash
No additional configuration is required for ONTAP tools to provide high availability. Only the vCenter Server and ESXi hosts must be configured with the VMware vSphere HA feature or the vSphere FT feature based on their requirements. Both HA and FT require clustered hosts together with shared storage. FT has additional requirements and limitations.
In addition to the VMware vSphere HA solution and vSphere FT solution, ONTAP tools also helps keep the ONTAP tools services running at all times.
Note vCenter HA is not supported by ONTAP tools.
