Add a storage backend
Storage backends are systems that the ESXi hosts use for data storage.
About this task
This task helps you to onboard an ONTAP cluster. When you add storage backend using ONTAP tools Manager, the storage backend is added to the global cluster. Associate the global cluster with a vCenter Server instance to enable an SVM user for vVols datastore provisioning.
When you add a storage backend using the vSphere client UI, vVols datastore does not support adding of an SVM user directly. |
Add storage backend using ONTAP tools Manager
A storage backend is global when added from ONTAP tools Manager or the ONTAP tools APIs. A storage backend is local when added from the vCenter Server APIs. For example, in a multi-tenant setup, you can add a storage backend (cluster) globally and SVM locally to use SVM user credentials. |
Steps
Launch ONTAP tools Manager from a web browser:
https://loadBalanceIP:8443/virtualization/ui/ -
Log in with the ONTAP tools for VMware vSphere administrator credentials you provided during deployment.
Select Storage Backends from the sidebar.
Select Add.
Provide the Server IP address or FQDN, username, and password details and select Add.
IPV4 and IPV6 management LIFs are supported. SVM user-based credentials with management LIFs are also supported.
Add storage backend using vSphere client UI:
Log in to the vSphere client using
https://vcenterip/ui -
In the shortcuts page, click on NetApp ONTAP tools under the plug-ins section.
In the left pane of ONTAP tools, navigate to Storage Backends and select Add.
In the Add Storage Backend window, provide the Server IP address, username, password, and port details and click Add.
You can add cluster-based credentials and IPV4 and IPV6 management LIFs or provide SVM-based credentials with management LIF of SVM to add an SVM user directly.
The list gets refreshed, and you can see the newly added storage backend in the list.
