ONTAP tools for VMware vSphere 10
Configure SRA for highly scaled environments
You should configure the storage timeout intervals per the recommended settings for Storage Replication Adapter (SRA) to perform optimally in highly scaled environments.
Storage Provider settings
You should set the following timeout values on VMware Live Site Recovery for scaled environment:
Advanced settings
Timeout values
StorageProvider.resignatureTimeout
Increase the value of the setting from 900 seconds to 12000 seconds.
storageProvider.hostRescanDelaySec
60
storageProvider.hostRescanRepeatCnt
20
storageProvider.hostRescanTimeoutSec
Set a high value (For example: 99999)
You should also enable the StorageProvider.autoResignatureMode option.
See the VMware documentation for more information on modifying Storage Provider settings.
Storage settings
When you hit a timeout, increase the values of storage.commandTimeout and storage.maxConcurrentCommandCnt to a higher value.
Note The timeout interval specified is the maximum value. You do not need to wait for the maximum timeout to be reached. Most commands finish within the set maximum timeout interval.
See the VMware documentation on modifying SAN Provider settings for more information.
