Configure SRA for highly scaled environments
You should configure the storage timeout intervals per the recommended settings for Storage Replication Adapter (SRA) to perform optimally in highly scaled environments.
Storage Provider settings
You should set the following timeout values on SRM for scaled environment:
Advanced settings |
Timeout values |
Increase the value of the setting from 900 seconds to 12000 seconds. |
60 |
20 |
Set a high value (For example: 99999) |
You should also enable the StorageProvider.autoResignatureMode option.
See the VMware documentation for more information on modifying Storage Provider settings.
Storage settings
When you hit a timeout, increase the values of storage.commandTimeout and storage.maxConcurrentCommandCnt to a higher value.
The timeout interval specified is the maximum value. You do not need to wait for the maximum timeout to be reached. Most commands finish within the set maximum timeout interval. |
See the VMware documentation on modifying SAN Provider settings for more information.
