ONTAP tools for VMware vSphere 10
Key concepts and terms
Contributors netapp-revathid
The following section describes the key concepts and terms used in the document.
ASA r2 systems
The new NetApp ASA r2 systems deliver a unified hardware and software solution that creates a simplified experience specific to the needs of SAN-only customers. Learn about ASA r2 storage systems.
Certificate authority (CA)
CA is a trusted entity that issues Secure Sockets Layer (SSL) certificates.
Consistency group
A consistency group is a collection of volumes that are managed as a single unit. In ONTAP, consistency groups provide easy management and a protection guarantee for an application workload spanning multiple volumes. Learn more about consistency group.
Dual stack
A dual-stack network is a networking environment that supports the simultaneous use of both IPv4 and IPv6 addresses.
High Availability (HA)
Cluster nodes are configured in HA pairs for non-disruptive operations.
Logical unit number (LUN)
A LUN is a number used to identify a logical unit within a Storage Area Network (SAN). These addressable devices are typically logical disks accessed through the Small Computer System Interface (SCSI) protocol or one of its encapsulated derivatives.
NVMe namespace and subsystem
An NVMe namespace is a quantity of non-volatile memory that can be formatted into logical blocks. Namespaces are the equivalent of LUNs for FC and iSCSI protocols, and an NVMe subsystem is analogous to an igroup. An NVMe subsystem can be associated with initiators so that namespaces within the subsystem can be accessed by the associated initiators.
ONTAP tools Manager
ONTAP tools Manager provides more control to ONTAP tools for VMware vSphere administrator over the managed vCenter Server instances and onboarded storage backends. ONTAP tools Manager helps in management of vCenter Server instances, storage backends, certificates, passwords and log bundle downloads.
Open Virtual Appliance (OVA)
OVA is an open standard for packaging and distributing virtual appliances or software that must be run on virtual machines.
Recovery Point Objective (RPO)
RPO is a measure of how frequently data is backed up or replicated. It represents the point in time to which data must be recovered after an outage in order to resume business operations. For example, if an organization has an RPO of 4 hours, it can tolerate losing up to 4 hours of data in the event of a disaster.
SnapMirror active sync (SMAS)
SnapMirror active sync enables business services to continue operating even through a complete site failure, supporting applications to fail over transparently using a secondary copy. Manual intervention nor custom scripting are required to trigger a failover with SnapMirror active sync. Learn more about SnapMirror active sync.
Storage backends
Storage backends are the underlying storage infrastructure that the ESXi host uses to store virtual machine files, data, and other resources. The storage backend allows the ESXi host to access and manage persistent data, providing the required storage capability and performance for virtualized environment.
Storage Replication Adapter (SRA)
SRA is the storage vendor specific software that is installed inside the VMware Live Site Recovery appliance. The adapter enables communication between Site Recovery Manager and a storage controller at the Storage Virtual Machine (SVM) level and the cluster level configuration.
Storage virtual machine (SVM)
Like a virtual machine running on a hypervisor, SVM is a logical entity that abstracts physical resources. SVM contains data volumes and one or more LIFs through which they serve data to the clients.
Uniform and non-uniform configuration
  • Uniform host access means that hosts from both sites are connected to all paths to storage clusters on both sites. Cross site paths are stretched across distance.
  • Non-uniform host access means hosts in each site are connected only to the cluster in the same site. Cross-site paths and stretched paths aren't connected.
    Note Uniform host access is supported for any SnapMirror active sync deployment; non-uniform host access is only supported for symmetric active/active deployments.
Virtual Machine File System (VMFS)
VMFS is a clustered file system specifically designed for storing virtual machine files in VMware vSphere environments.
Virtual volumes (vVols)
vVols provide a volume-level abstraction for storage used by a virtual machine. It includes several benefits and provides an alternative to using a traditional LUN. A vVol datastore is typically associated with a single LUN which acts as a container for the vVols.
VM Storage Policy
VM Storage Policies are created in vCenter Server under Policies and Profiles. For vVols, create a rule set using rules from the NetApp vVols storage type provider.
VMware Live Site Recovery provides business continuity, disaster recovery, site migration, and non-disruptive testing capabilities for VMware virtual environments.
VMware vSphere APIs for Storage Awareness (VASA)
VASA is a set of APIs that integrate storage arrays with vCenter Server for management and administration. The architecture is based on several components including the VASA Provider which handles communication between VMware vSphere and the storage systems.
VMware vSphere Storage APIs - Array Integration (VAAI)
VAAI is a set of APIs that enables communication between VMware vSphere ESXi hosts and the storage devices. The APIs include a set of primitive operations used by the hosts to offload storage operations to the array. VAAI can provide significant performance improvements for storage-intensive tasks.
vSphere Metro Storage Cluster
vSphere Metro Storage Cluster (vMSC) is a technology that enables and supports vSphere in a stretched cluster deployment. vMSC solutions are supported with NetApp MetroCluster and SnapMirror active sync (formerly SMBC). These solutions provide enhanced business continuity in the case of domain failure. The resiliency model is based on your specific configuration choices. Learn more about VMware vSphere Metro Storage Cluster.
vVols datastore
The vVols datastore is a logical datastore representation of a vVols container which is created and maintained by a VASA Provider.
Zero RPO
RPO stands for recovery point objective, which is the amount of data loss deemed acceptable during a given time. Zero RPO signifies that no data loss is acceptable.
