Configure placeholder datastores
You should configure a placeholder datastore to hold a place in the vCenter inventory at the recovery site for the protected virtual machine (VM). The placeholder datastore does not need to be large as the placeholder VMs are small and use only a few hundred or fewer kilobytes.
Before you begin
You should have connected the protected and recovery sites.
You should have configured your resource mappings.
Steps
Log in to vCenter Server and select Site Recovery > Sites.
Select your protected site and select Manage.
Select Placeholder Datastores > New in the manage tab to create a new placeholder datastore.
Select the appropriate datastore and select OK.
Placeholder datastores can be local or remote and should not be replicated. -
Repeat steps 3 to 5 to configure a placeholder datastore for the recovery site.
