ONTAP tools for VMware vSphere 10
Configure placeholder datastores
You should configure a placeholder datastore to hold a place in the vCenter inventory at the recovery site for the protected virtual machine (VM). The placeholder datastore does not need to be large as the placeholder VMs are small and use only a few hundred or fewer kilobytes.
What you will need
  • You should have connected the protected and recovery sites.
  • You should have configured your resource mappings.
Steps
  1. Log in to vCenter Server and click on Site Recovery > Sites.
  2. Select your protected site, and then click Manage.
  3. In the Manage tab, select Placeholder Datastores.
  4. Click New to create a new placeholder datastore.
  5. Select the appropriate datastore, and then click OK.
    Note Placeholder datastores can be local or remote and should not be replicated.
  6. Repeat steps 3 to 5 to configure a placeholder datastore for the recovery site.
