ONTAP tools for VMware vSphere 105
ONTAP tools REST API implementation details
Contributors netapp-revathid
While REST establishes a common set of technologies and best practices, the exact implementation of each API can vary based on the design choices. You should be familiar with how the ONTAP tools for VMware vSphere 10 REST API is designed before using it.
The REST API includes several resource categories such as vCenters and Aggregates. Review the API reference for more information.
How to access the REST API
You can access the ONTAP tools for VMware vSphere 10 REST API through the ONTAP tools IP address along with the port. There are several parts to the complete URL, including:
  • ONTAP tools IP address and port
  • API version
  • Resource category
  • Specific resource
You must configure the IP address during initial setup, while the port remains fixed at 8443. The first part of the URL is consistent for each ONTAP tools for VMware vSphere 10 instance; only the resource category and specific resource change between endpoints.
Caution The IP address and port values in the examples below are for illustration purposes only. You need to change these values for your environment.
Example to access authentication services
https://10.61.25.34:8443/virtualization/api/v1/auth/login
This URL can be used to request an access token using the POST method.
Example to list the vCenter servers
https://10.61.25.34:8443/virtualization/api/v1/vcenters
This URL can be used to request a list of the defined vCenter server instances using the GET method.
HTTP details
The ONTAP tools for VMware vSphere 10 REST API uses HTTP and related parameters to act on the resource instances and collections. Details of the HTTP implementation are presented below.
HTTP methods
The HTTP methods or verbs supported by the REST API are presented in the table below.
Method CRUD Description
GET
Read
Retrieves object properties for a resource instance or collection. This is considered a list operation when used with a collection.
POST
Create
Creates a new resource instance based on the input parameters.
PUT
Update
Updates an entire resource instance with the supplied JSON request body. Key values that aren't user-modifiable are preserved.
PATCH
Update
Requests a set of selected changes in the request be applied to the resource instance.
DELETE
Delete
Deletes an existing resource instance.
Request and response headers
The following table summarizes the most important HTTP headers used with the REST API.
Header Type Usage notes
Accept
Request
This is the type of content the client application can accept. Valid values include '*/*` or application/json.
x-auth
Request
Contains an access token identifying the user issuing the request through the client application.
Content-Type
Returned by the server based on the Accept request header.
HTTP status codes
The HTTP status codes used by the REST API are described below.
Code Meaning Description
200
OK
Indicates success for calls that don't create a new resource instance.
201
Created
An object has been successfully created with a unique identifier for the resource instance.
202
Accepted
The request has been accepted and a background job created to perform the request.
204
No content
The request was successful although no content was returned.
400
Bad request
The request input is not recognized or is inappropriate.
401
Unauthorized
The user is not authorized and must authenticate.
403
Forbidden
Access is denied due to an authorization error.
404
Not found
The resource referred to in the request doesn't exist.
409
Conflict
An attempt to create an object failed because the object already exists.
500
Internal error
A general internal error occurred at the server.
Authentication
Authentication of a client to the REST API is performed using an access token. The relevant characteristics of the token and authentication process include:
  • The client must request a token using ONTAP tools Manager admin credentials (username and password).
  • Tokens are formatted as a JSON Web Token (JWT).
  • Each token expires after 60 minutes.
  • API requests from a client must include the token in the x-auth request header.
Refer to Your first REST API call for an example of requesting and using an access token.
Synchronous and asynchronous requests
Most REST API calls complete quickly and therefore run synchronously. That is, they return a status code (such as 200) after a request has been completed. Requests that take longer to complete run asynchronously using a background job.
After issuing an API call that runs asynchronously, the server returns a 202 HTTP status code. This indicates the request has been accepted but not yet completed. You can query the background job to determine its status including success or failure.
Asynchronous processing is used for several types of long running operations, including datastore and vVol operations. Refer to the job manager category of the REST API at the Swagger page for more information.
