ONTAP tools for VMware vSphere 105
vCenter Server RBAC considerations for ONTAP tools
Contributors netapp-revathid
There are several aspects of the ONTAP tools for VMware vSphere 10 RBAC implementation with vCenter Server you should consider before using it in a production environment.
vCenter roles and the administrator account
You only need to define and use the custom vCenter Server roles if you want to limit access to the vSphere objects and associated administrative tasks. If limiting access is not required, you can use an administrator account instead. Each administrator account is defined with the Administrator role at the top level of the object hierarchy. This provides full access to the vSphere objects, including those added by ONTAP tools for VMware vSphere 10.
vSphere object hierarchy
The vSphere object inventory is organized in a hierarchy. For example, you can move down the hierarchy as follows:
vCenter Server -→ Datacenter -→ Cluster -→ ESXi host -→ Virtual Machine
All permissions are validated in the vSphere object hierarchy except the VAAI plug-in operations, which are validated against the target ESXi host.
Roles included with ONTAP tools for VMware vSphere 10
To simplify working with vCenter Server RBAC, ONTAP tools for VMware vSphere provides predefined roles tailored to various administrative tasks.
Note You can create new custom roles if needed. To do so, clone one of the existing ONTAP tools roles and edit it as needed. After making the configuration changes, the affected vSphere client users need to log out and log back in to activate the changes.
To view the ONTAP tools for VMware vSphere roles, select Menu at the top of the vSphere Client and click Administration and then Roles on the left.
The following privileges must be included in the role assigned to the vCenter user responsible for deploying or onboarding vCenter Server. Ensure these privileges are configured as a prerequisite for the deployment or onboarding process.
  • Alarms
    • Acknowledge alarm
  • Content Library
    • Add library item
    • Check in a template
    • Check out a template
    • Download files
    • Import storage
    • Read storage
    • Sync library item
    • Sync subscribed library
    • View configuration settings
  • Datastore
    • Allocate space
    • Browse datastore
    • Low level file operations
    • Remove file
    • Update virtual machine files
    • Update virtual machine metadata
  • ESX Agent Manager
    • View
  • Folder
    • Create folder
  • Host
    • Configuration
      • Advanced settings
      • Change settings
      • Network configuration
      • System resources
      • Virtual machine autostart configuration
    • Local operations
      • Create virtual machine
      • Delete virtual machine
      • Reconfigure virtual machine
  • Network
    • Assign network
    • Configure
  • OvfManager
    • OvfConsumer Access
  • Host profile
    • View
  • Resource
    • Assign virtual machine to resource pool
  • Scheduled task
    • Create tasks
    • Modify task
    • Run task
  • Tasks
    • Create task
    • Update task
  • vApp
    • Add virtual machine
    • Assign resource pool
    • Assign vApp
    • Create
    • Import
    • Move
    • Power off
    • Power on
    • Pull from URL
    • View OVF environment
  • Virtual machine
    • Change Configuration
      • Add existing disk
      • Add new disk
      • Add or remove device
      • Advanced configuration
      • Change CPU count
      • Change Memory
      • Change Settings
      • Change resource
      • Extend virtual disk
      • Modify device settings
      • Remove disk
      • Reset guest information
      • Upgrade virtual machine compatibility
    • Edit Inventory
      • Create from existing
      • Create new
      • Move
      • Register
      • Remove
      • Unregister
    • Interaction
      • Backup operation on virtual machine
      • Configure CD media
      • Configure floppy media
      • Connect devices
      • Console interaction
      • Guest operating system management by VIX API
      • Power off
      • Power on
      • Reset
      • Suspend
    • Provisioning
      • Allow disk access
      • Clone template
      • Customize guest
      • Deploy template
      • Modify customization specification
      • Read customization specifications
    • Snapshot management
      • Create snapshot
      • Remove snapshot
      • Rename snapshot
      • Revert to snapshot
There are three predefined roles as described below.
NetApp ONTAP tools for VMware vSphere Administrator
Provides all the native vCenter Server privileges and ONTAP tools-specific privileges required to perform core ONTAP tools for VMware vSphere administrator tasks.
NetApp ONTAP tools for VMware vSphere Read Only
Provides read-only access to ONTAP tools. These users cannot perform any ONTAP tools for VMware vSphere actions that are access-controlled.
NetApp ONTAP tools for VMware vSphere Provision
Provides some of the native vCenter Server privileges and ONTAP tools-specific privileges that are required to provision storage. You can perform the following tasks:
  • Create new datastores
  • Manage datastores
vSphere objects and ONTAP storage backends
The two RBAC environments work together. When performing a task in the vSphere client interface, the ONTAP tools roles defined to vCenter Server are checked first. If the operation is permitted by vSphere, then the ONTAP role privileges are examined. This second step is performed based on the ONTAP role assigned to the user when the storage backend was created and configured.
Working with vCenter Server RBAC
There are a few things to consider when working with the vCenter Server privileges and permissions.
Required privileges
To access the ONTAP tools for VMware vSphere 10 user interface, you need to have the ONTAP tools-specific View privilege. If you sign in to vSphere without this privilege and click the NetApp icon, ONTAP tools for VMware vSphere displays an error message and prevents you from accessing the user interface.
The assignment level in the vSphere object hierarchy determines which portions of the user interface you can access. Assigning the View privilege to the root object enables you to access ONTAP tools for VMware vSphere by clicking the NetApp icon.
You can instead assign the View privilege to another lower vSphere object level. However, this will limit the ONTAP tools for VMware vSphere menus that you can access and use.
Assigning permissions
You need to use vCenter Server permissions if you want to limit access to the vSphere objects and tasks. Where you assign permission in the vSphere object hierarchy determines the ONTAP tools for VMware vSphere 10 tasks users can perform.
Tip Unless you need to define more restrictive access, it's generally a good practice to assign permissions at the root object or root folder level.
The permissions available with ONTAP tools for VMware vSphere 10 apply to custom non-vSphere objects, such as storage systems. If possible, you should assign these permissions to ONTAP tools for VMware vSphere root object because there is no vSphere object you can assign it to. For example, any permission that includes an ONTAP tools for VMware vSphere "Add/Modify/Remove storage systems" privilege should be assigned at the root object level.
When defining a permission at a higher level in the object hierarchy, you can configure the permission so it is passed down and inherited by the child objects. If needed you can assign additional permissions to the child objects that override the permissions inherited from the parent.
You can modify a permission at any time. If you change any of the privileges within a permission, users associated with the permission need to log out of vSphere and log back in to enable the change.
