ESXi host values set using ONTAP tools
You can set timeouts and other values on the ESXi hosts using ONTAP tools for VMware vSphere to ensure best performance and successful failover. The values that ONTAP tools sets are based on internal NetApp testing.
You can set the following values on an ESXi host:
ESXi advanced configuration
VMFS3.HardwareAcceleratedLocking
You should set this value to 1.
VMFS3.EnableBlockDelete
You should set this value to 0.
NFS settings
Net.TcpipHeapSize
If you are using vSphere 6.0 or later, you should set this value to 32.
Net.TcpipHeapMax
If you are using vSphere 6.0 or later, for ESXi host 6.x set the value to 512 and for ESXi 7.x to 1024.
NFS.MaxVolumes
If you are using vSphere 6.0 or later, you should set this value to 256.
NFS41.MaxVolumes
NFS.MaxQueueDepth
If you are using the vSphere 6.0 or later version of ESXi host, then you should set this value to 128 or higher to avoid queuing bottlenecks.
For vSphere versions prior to 6.0, you should set this value to 64.
NFS.HeartbeatMaxFailures
You should set this value to 10 for all NFS configurations.
NFS.HeartbeatFrequency
You should set this value to 12 for all NFS configurations.
NFS.HeartbeatTimeout
You should set this value to 5 for all NFS configurations.
FC/FCoE settings
Path selection policy
You should set this value to “RR” (round robin) when FC paths with ALUA are used.
You should set this value to “FIXED” for all other configurations.
Setting this value to “RR” helps to provide load balancing across all of the active/optimized paths. The value “FIXED” is used for older, non-ALUA configurations and helps to prevent proxy I/O.
Disk.QFullSampleSize
You should set this value to 32 for all configurations. Setting this value helps to prevent I/O errors.
Disk.QFullThreshold
You should set this value to 8 for all configurations. Setting this value helps prevent I/O errors.
Emulex FC HBA timeouts
Use the default value.
QLogic FC HBA timeouts
iSCSI settings
You should set this value to “RR” for all iSCSI paths.
Disk.QFullThreshold
