ONTAP tools for VMware vSphere 9.12
Delete vVols datastores
Delete vVOL datastore task from ONTAP tools in the VCenter does the following:
  • Unmounts the vVol container.
  • Cleans up Igroup. If igroup is not in use, removes iqn from igroup.
  • Deletes Vvol container.
  • Leaves the Flex volumes on the storage array.
Follow the steps below to delete vVOL datastore from ONTAP Tools from the vCenter:
Steps:
  1. From the Inventory view select the datastore.
  2. Right click on the vVol datastore and select NetApp Ontap tools > Delete vVols datastore.
  3. Clean up the Flex volumes at the Storage array and the igroup.
