Delete vVols datastores
Delete vVOL datastore task from ONTAP tools in the VCenter does the following:
Unmounts the vVol container.
Cleans up Igroup. If igroup is not in use, removes iqn from igroup.
Deletes Vvol container.
Leaves the Flex volumes on the storage array.
Follow the steps below to delete vVOL datastore from ONTAP Tools from the vCenter:
Steps:
From the Inventory view select the datastore.
Right click on the vVol datastore and select NetApp Ontap tools > Delete vVols datastore.
Clean up the Flex volumes at the Storage array and the igroup.
