ONTAP tools for VMware vSphere 9.8
Privileges required for VSC tasks
Contributors manishc
Different ONTAP tools for VMware vSphere tasks require different combinations of privileges specific to Virtual Storage Console (VSC) and native vCenter Server privileges.
Information about the privileges required for VSC tasks is available in the NetApp Knowledgebase article 1032542.
Product-level privilege required by ONTAP tools for VMware vSphere
To access the ONTAP tools for VMware vSphere GUI, you must have the product-level, VSC-specific View privilege assigned at the correct vSphere object level. If you log in without this privilege, VSC displays an error message when you click the NetApp icon and prevents you from accessing VSC.
The following information describes the VSC product-level View privilege:
Privilege
Assignment level
View
You can access the VSC GUI. This privilege does not enable you to perform tasks within VSC. To perform any VSC tasks, you must have the correct VSC-specific and native vCenter Server privileges for those tasks.
The assignment level determines which portions of the UI you can see. Assigning the View privilege at the root object (folder) enables you to enter VSC by clicking the NetApp icon.
You can assign the View privilege to another vSphere object level; however, doing that limits the VSC menus that you can see and use.
The root object is the recommended place to assign any permission containing the View privilege.
