Standard roles packaged with ONTAP tools
To simplify working with vCenter Server privileges and role-based access control (RBAC), ONTAP tools provide standard ONTAP tools roles that enable you to perform key ONTAP tools tasks. There is also a read-only role that enables you to view the information, but not perform any tasks.
The standard ONTAP tools roles have both the required ONTAP tools-specific privileges and the native vCenter Server privileges that are required for users to perform ONTAP tools tasks. In addition, the roles are set up so that they have the required privileges across all supported versions of the vCenter Server.
As an administrator, you can assign these roles to users as required.
When you upgrade ONTAP tools to the latest version, the standard roles are automatically upgraded to work with the new version of the tool. |
You can view the ONTAP tools standard roles by clicking Roles on the vSphere Client Home page.
The roles that ONTAP tools provides enable you to perform the following tasks:
Role |
Description |
VSC Administrator |
Provides all of the native vCenter Server privileges and ONTAP tools-specific privileges that are required to perform all ONTAP tools tasks. |
VSC Read-only |
Provides read-only access to ONTAP tools. These users cannot perform any ONTAP tools for VMware vSphere actions that are access-controlled. |
VSC Provision |
Provides all of the native vCenter Server privileges and ONTAP tools-specific privileges that are required to provision storage. You can perform the following tasks:
Guidelines for using ONTAP tools standard roles
When you work with standard ONTAP tools for VMware vSphere roles, there are certain guidelines you should follow.
You should not directly modify the standard roles. If you do, ONTAP tools will overwrite your changes each time you upgrade. The installer updates the standard role definitions each time you upgrade ONTAP tools. Doing this ensures that the roles are current for your version of ONTAP tools for VMware vSphere as well as for all supported versions of the vCenter Server.
You can, however, use the standard roles to create roles that are tailored to your environment. To do this, you should copy the ONTAP tools standard role and then edit the copied role. By creating a new role, you can maintain this role even when you restart or upgrade the ONTAP tools Windows service.
Some of the ways that you might use the ONTAP tools standard roles include the following:
Use the standard ONTAP tools roles for all ONTAP tools tasks.
In this scenario, the standard roles provide all the privileges a user needs to perform the ONTAP tools tasks.
Combine roles to expand the tasks a user can perform.
If the standard ONTAP tools roles provide too much granularity for your environment, you can expand the roles by creating higher-level groups that contain multiple roles.
If a user needs to perform other, non-ONTAP tools tasks that require additional native vCenter Server privileges, you can create a role that provides those privileges and add it to the group also.
Create more fine-grained roles.
If your company requires that you implement roles that are more restrictive than the standard ONTAP tools roles, you can use the ONTAP tools roles to create new roles.
In this case, you would clone the necessary ONTAP tools roles and then edit the cloned role so that it has only the privileges your user requires.
