Manage ONTAP ARP attack detection parameters
Contributors netapp-dbagwell
Beginning with ONTAP 9.11.1, you can modify the parameters for ransomware detection on a specific ARP-enabled NAS volume and report a known surge as normal file activity. Adjusting detection parameters helps improve the accuracy of reporting based on your specific volume workload.
Note If you are running ONTAP 9.16.1 or later, see Manage ARP/AI attack detection parameters.
How ARP attack detection works
When Autonomous Ransomware Protection (ARP) is in learning mode, it develops baseline values for volume behaviors. These include entropy, file extensions, and beginning with ONTAP 9.11.1, IOPS. These baselines are used to evaluate ransomware threats. For more information about these criteria, see what ARP detects.
In ONTAP 9.10.1, ARP issues a warning if it detects both of the following conditions:
  • More than 20 files with file extensions not previously observed in the volume
  • High entropy data
In ONTAP 9.10.1, a low-threat warning escalates to a moderate threat after 100 or more files are affected.
Beginning with ONTAP 9.11.1, ARP issues a threat warning if either condition is met. For example, if more than 20 files with file extensions not previously observed in the volume are detected within a 24-hour period, ARP categorizes this as a threat regardless of observed entropy. The 24-hour and 20-file values are defaults, which can be modified.
Note To reduce high numbers of false positive alerts, go to Storage > Volumes > Security > Configure workload characteristics and disable Monitor new file types. This setting is disabled by default in ONTAP 9.14.1 P7 and 9.15.1 P1.
ARP does not evaluate SAN volumes in ONTAP 9.10.1 to 9.15.1. Beginning with ONTAP 9.17.1, SAN volumes are supported by ARP/AI only.
Beginning with ONTAP 9.14.1, you can configure alerts when ARP observes a new file extension and when ARP creates a snapshot. For more information, see Configure ARP alerts.
Modify ARP attack detection parameters
Depending on the expected behaviors of the ARP-enabled NAS volume, you might want to modify the attack detection parameters.
Steps
  1. View the existing attack detection parameters:
    security anti-ransomware volume attack-detection-parameters show -vserver <svm_name> -volume <volume_name>
    security anti-ransomware volume attack-detection-parameters show -vserver vs1 -volume vol1
                                                 Vserver Name : vs1
                                                  Volume Name : vol1
                Is Detection Based on High Entropy Data Rate? : true
      Is Detection Based on Never Seen before File Extension? : true
                      Is Detection Based on File Create Rate? : true
                      Is Detection Based on File Rename Rate? : true
                      Is Detection Based on File Delete Rate? : true
               Is Detection Relaxing Popular File Extensions? : true
                    High Entropy Data Surge Notify Percentage : 100
                     File Create Rate Surge Notify Percentage : 100
                     File Rename Rate Surge Notify Percentage : 100
                     File Delete Rate Surge Notify Percentage : 100
     Never Seen before File Extensions Count Notify Threshold : 20
           Never Seen before File Extensions Duration in Hour : 24
  2. All the fields shown are modifiable with boolean or integer values. To modify a field, use the security anti-ransomware volume attack-detection-parameters modify command.
    Learn more about security anti-ransomware volume attack-detection-parameters modify in the ONTAP command reference.
Report known surges
ARP continues to modify baseline values for detection parameters even when active. If you know of surges in your volume activity, either one-time surges or a surge that is characteristic of a new normal, you should report them as safe. Manually reporting these surges as safe helps improve the accuracy of ARP's threat assessments.
Report a one-time surge
  1. If a one-time surge is occurring under known circumstances and you want ARP to report a similar surge in future circumstances, clear the surge from the workload behavior:
    security anti-ransomware volume workload-behavior clear-surge -vserver <svm_name> -volume <volume_name>
    Learn more about security anti-ransomware volume workload-behavior clear-surge in the ONTAP command reference.
Modify baseline surge
  1. If a reported surge should be considered normal application behavior, report the surge as such to modify the baseline surge value:
    security anti-ransomware volume workload-behavior update-baseline-from-surge -vserver <svm_name> -volume <volume_name>
    Learn more about security anti-ransomware volume workload-behavior update-baseline-from-surge in the ONTAP command reference.
Beginning with ONTAP 9.14.1, ARP allows you to specify alerts for two events:
  • Observation of a new file extension on a volume
  • Creation of an ARP snapshot
Alerts for these two events can be set on individual volumes or for the entire SVM. If you enable alerts for the SVM, the alert settings are inherited only by volumes created after you enable the alert. By default, alerts are not enabled on any volume.
Event alerts can be controlled with multi-admin verification. For more information, see Multi-admin verification with ARP-protected volumes.
Steps
You can use System Manager or the ONTAP CLI to set alerts for ARP events.
System Manager
Set alerts for a volume
  1. Navigate to Volumes. Select the individual volume for which you want to modify settings.
  2. Select the Security tab then Event severity settings.
  3. To receive alerts for New file extension detected and Ransomware snapshot created, select the dropdown menu under the Severity heading. Modify the setting from Don't generate event to Notice.
  4. Select Save.
Set alerts for an SVM
  1. Navigate to Storage VM then select the SVM for which you want to enable settings.
  2. Under the Security heading, locate the Anti-ransomware card. Select Menu options icon then Edit Ransomware Event Severity.
  4. Select Save.
CLI
  • To set alerts for a new file extension:
    security anti-ransomware volume event-log modify -vserver <svm_name> -volume <volume_name> -is-enabled-on-new-file-extension-seen true
  • To set alerts for the creation of an ARP snapshot:
    security anti-ransomware volume event-log modify -vserver <svm_name> -volume <volume_name> -is-enabled-on-snapshot-copy-creation true
  • Confirm your settings with the anti-ransomware volume event-log show command.
    security anti-ransomware vserver event-log modify -vserver <svm_name> -is-enabled-on-new-file-extension-seen true
    security anti-ransomware vserver event-log modify -vserver <svm_name> -is-enabled-on-snapshot-copy-creation true
  • Confirm your settings with the security anti-ransomware vserver event-log show command.
Learn more about security anti-ransomware vserver event-log commands in the ONTAP command reference.
