      Create backup policies
In the left Navigator pane of the VMware vSphere web client, click Policies, and then click
 New Policy. -
On the New Backup Policy page, enter the policy configuration information, and then click Add.
If the policy will be used for mirror-vault relationships, then in the Replication field, you must select only the Update SnapVault after backup option if you want backups copied to the mirror-vault destinations.
