Create backup policies
In the left Navigator pane of the VMware vSphere web client, click Policies, and then click
New Policy.
On the New Backup Policy page, enter the policy configuration information, and then click Add.
If the policy will be used for mirror-vault relationships, then in the Replication field, you must select only the Update SnapVault after backup option if you want backups copied to the mirror-vault destinations.
