Restore VMDKs from backups
You can restore existing VMDKs, or deleted or detached VMDKs, from either a primary or secondary backup.
You can restore one or more virtual machine disks (VMDKs) on a VM to the same datastore.
For improved performance of restore operations in NFS environments, enable the VMware application vStorage API for Array Integration (VAAI). |
A backup must exist.
You must have created a backup of the VM using the SnapCenter Plug-in for VMware vSphere.
The VM must not be in transit.
The VM that you want to restore must not be in a state of vMotion or Storage vMotion.
If the VMDK is deleted or detached from the VM, then the restore operation attaches the VMDK to the VM.
A restore operation might fail if the storage tier of the FabricPool where the VM is located is unavailable.
Attach and restore operations connect VMDKs using the default SCSi controller. VMDKs that are attached to a VM with a NVME controller are backed up, but for attach and restore operations they are connected back using a SCSi controller.
In the VMware vSphere web client GUI, click Menu in the toolbar, and then select VMs and Templates from the drop-down list.
In the left Navigator pane, right-click a VM, then select NetApp SnapCenter in the drop-down list, and then select Restore in the secondary drop-down list.
In the Restore wizard, on the Select Backup page, select the backup copy that you want to restore from.
You can search for a specific backup name or a partial backup name, or you can filter the backup list by clicking the filter icon and selecting a date and time range, selecting whether you want backups that contain VMware Snapshots, whether you want mounted backups, and primary or secondary location. Click OK to return to the wizard.
On the Select Scope page, select the restore destination.
To restore to… Specify the restore destination… The original datastore
Select Particular disk from the drop-down list and then click Next.
In the Datastore selection table, you can select or unselect any VMDKs.An alternate datastore in an alternate location
Click the destination datastore and select a different datastore from the list.
On the Select Location page, select the Snapshot copy that you want to restore (primary or secondary).
Review the Summary page and then click Finish.
Optional: Monitor the operation progress by clicking Recent Tasks at the bottom of the screen.
Refresh the screen to display updated information.
