Audit logs
Audit log is a collection of events in a chronological order, which is written to a file within the appliance. The audit log files are generated at /var/log/netapp/audit location and the file names follow one of the below naming conventions:
audit.log: Active audit log file that is in use.
audit-%d{yyyy-MM-dd-HH-mm-ss}.log.gz: Rolled over audit log file. The date and time in the file name indicates when the file was created, for example: audit-2022-12-15-16-28-01.log.gz.
In the SCV plug-in user interface, you can view and export the audit log details from
Dashboard > Settings > Audit Logs Tab
You can view operation audit in the audit logs. The audit logs are downloaded with the Support bundle.
If Email settings are configured, SCV sends an Email notification in the event of an Audit Log Integrity Verification failure. An Audit Log Integrity Verification failure can happen when one of the files is tampered or deleted.
The default configurations of the audit files are:
Audit log file in use can grow to a maximum of 10 MB
A maximum of 10 audit log files are retained
To modify the default configurations add a key value pair in the /opt/netapp/scvservice/standalone_aegis/etc/scbr/scbr.properties and restart the scvservice.
The configurations for audit log files are:
auditMaxROFiles=<xx>, where xx is the max number of rolled over audit log files, for example: auditMaxROFiles=15.
auditLogSize=<XX>MB, where xx is the size of the file in MB, for example: auditLogSize=15MB.
Rolled over audit logs are periodically verified for integrity. SCV provides REST APIs to view logs and verify their integrity. A built-in schedule triggers and assigns one of the following integrity statuses.
Status  |
Description  |
TAMPERED  |
Audit log file content is modified  |
NORMAL  |
Audit log file is unmodified  |
ROLLOVER DELETE  |
* Audit log file is deleted based on retention  |
UNEXPECTED DELETE  |
Audit log file is deleted  |
ACTIVE  |
* Audit log file is in use  |
Events are categorize into three major categories:
Data Protection Events
Maintenance Console Events
Admin Console Events
The resources in SCV are:
Storage System
Resource Group
Policy
Backup
The following table lists the operations that can be performed on each resource:
Resources  |
Operations  |
Storage System  |
Created, Modified, Deleted  |
Resource Group  |
Created, Modified, Deleted, Suspended, Resumed  |
Policy  |
Backup  |
Created, Renamed, Deleted, Mounted, Unmounted, Restored VMDK, Restored VM, Attach VMDK, Detach VMDK, Guest File Restore  |
The administrative operations in the maintenance console are audited.
Available maintenance console options are:
Start / Stop services
Change username & password
Change MySQL password
Configure MySQL Backup
Restore MySQL Backup
Change 'maint' user password
Change time zone
Change NTP Server
Disable SSH access
Increase jail disk size
Upgrade
Install VMware Tools (We are working on replace this with open-vm tools)
Change IP address settings
Change domain name search settings
Change static routes
Access diagnostic shell
Enable remote diagnostic access
The following operations in the Admin Console UI are audited:
Settings
Change admin credentials
Change timezone
Change NTP Server
Change IPv4 / IPv6 settings
Configuration
Change vCenter Credentials
Plug-in Enable / Disable
