REST API workflow to modify built-in schedules
To modify built-in schedules for VMware vSphere client jobs using the SnapCenter Plug-in for VMware vSphere REST APIs, you must follow the prescribed sequence of REST API calls.
Built-in schedules are the schedules that are provided as part of the product; for example, the MySQL database dump schedule. You can modify the following schedules:
Schedule-DatabaseDump
Schedule-PurgeBackups
Schedule-AsupDataCollection
Schedule-ComputeStorageSaving
Schedule-PurgeJobs
For each REST API, add https://<server>:<port> at the front of the REST API to form a complete endpoint.
Step REST API Comments
1
/4.1/schedules
Get all built-in schedules gets a list of the job schedules that were originally provided in the product.
Note the schedule name that you want to modify and the associated cron expression.
2
/4.1/schedules
Modify any built-in schedule changes the named schedule.
Pass the schedule name from Step 1 and create a new cron expression for the schedule.
