Modify the logon credentials
You can modify the logon credentials for the SnapCenter Plug-in for VMware vSphere management GUI.
You must know the IP address and the log on credentials for the SnapCenter Plug-in for VMware vSphere management GUI. You must also note down the MFA token generated from the maintenance console.
The IP address was displayed when the SnapCenter Plug-in for VMware vSphere was deployed.
Use the log in credentials provided during the deployment of the SnapCenter Plug-in for VMware vSphere or as later modified.
Generate a 6-digit MFA token using the maintenance console System Configuration options.
Log in to the SnapCenter Plug-in for VMware vSphere management GUI.
Use the format
https://<appliance-IP-address>:8080 -
Click the Settings icon in the top toolbar.
On the Settings page, in the User section, click Edit.
Enter the new password and click Save.
It might take several minutes before all the services come back up.
