Minimum vCenter privileges required
Contributors netapp-revathid
Before you begin deployment of SnapCenter Plug-in for VMware vSphere, you should make sure you have the minimum required vCenter privileges.
Required privileges for vCenter Admin role
Datastore.AllocateSpace
Datastore.Browse
Datastore.Delete
Datastore.FileManagement
Datastore.Move
Datastore.Rename
Extension.Register
Extension.Unregister
Extension.Update
Host.Config.AdvancedConfig
Host.Config.Resources
Host.Config.Settings
Host.Config.Storage
Host.Local.CreateVM
Host.Local.DeleteVM
Host.Local.ReconfigVM
Network.Assign
Resource.ApplyRecommendation
Resource.AssignVMToPool
Resource.ColdMigrate
Resource.HotMigrate
Resource.QueryVMotion
System.Anonymous
System.Read
System.View
Task.Create
Task.Update
VirtualMachine.Config.AddExistingDisk
VirtualMachine.Config.AddNewDisk
VirtualMachine.Config.AdvancedConfig
VirtualMachine.Config.ReloadFromPath
VirtualMachine.Config.RemoveDisk
VirtualMachine.Config.Resource
VirtualMachine.GuestOperations.Execute
VirtualMachine.GuestOperations.Modify
VirtualMachine.GuestOperations.Query
VirtualMachine.Interact.PowerOff
VirtualMachine.Interact.PowerOn
VirtualMachine.Inventory.Create
VirtualMachine.Inventory.CreateFromExisting
VirtualMachine.Inventory.Delete
VirtualMachine.Inventory.Move
VirtualMachine.Inventory.Register
VirtualMachine.Inventory.Unregister
VirtualMachine.State.CreateSnapshot
VirtualMachine.State.RemoveSnapshot
VirtualMachine.State.RevertToSnapshot
Required privileges specific to SnapCenter Plug-in for VMware vCenter
Privileges
Label
netappSCV.Guest.RestoreFile
Guest File Restore
netappSCV.Recovery.MountUnMount
Mount/Unmount
netappSCV.Backup.DeleteBackupJob
Delete Resource Group/Backup
netappSCV.Configure.ConfigureStorageSystems.Delete
Remove Storage Systems
netappSCV.View
View
netappSCV.Recovery.RecoverVM
Recover VM
netappSCV.Configure.ConfigureStorageSystems.AddUpdate
Add/Modify Storage Systems
netappSCV.Backup.BackupNow
Backup Now
netappSCV.Guest.Configure
Guest Configuration
netappSCV.Configure.ConfigureSnapCenterServer
Configure SnapCenter Server
netappSCV.Backup.BackupScheduled
Create Resource Group
