The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Your file is ready
To perform add and modify storage VM operations using the SnapCenter Plug-in for VMware vSphere REST APIs, you must follow the prescribed sequence of REST API calls.
For each REST API, add https://<server>:<port> at the front of the REST API to form a complete endpoint.
To add storage VM operations, follow this workflow:
Step
REST API
Comments
1
/4.1/storage-system
Add Storage System adds the specified storage VM to SnapCenter Plug-in for VMware vSphere.
To modify storage VM operations, follow this workflow:
Step
REST API
Comments
1
/4.1/storage-system
getSvmAll gets the list of all available storage VMs.
Note the name of the storage VM that you want to modify.
2
/4.1/storage-system
Modify Storage System modifies the specified storage VM.
Pass the name from Step 1 in addition to all the other required attributes.
