SnapCenter Plug-in for VMware vSphere 6.0
Upgrade paths
Contributors netapp-sumathi
The version of SnapCenter Plug-in for VMware vSphere (SCV) that you can upgrade to depends on the version that you're currently running.
Note
Upgrade to SnapCenter Plug-in for VMware vSphere (SCV) 4.8 and above is supported only on VMware vCenter server 7 update 1 and later versions. For VMware vCenter server prior to version 7 update 1, you should continue to use SCV 4.7.
If you are on SCV version… You can directly upgrade SCV to…
SCV 5.0
SCV 6.0
SCV 4.9
SCV 5.0 and SCV 6.0
SCV 4.8
SCV 4.9 and SCV 5.0
SCV 4.7
SCV 4.8 and SCV 4.9
For virtualized databases and file systems that are integrated with SnapCenter, this is the upgrade path:
If you are using If your VMware plug-in is… You can directly upgrade to…
SnapCenter 6.0
SCV 5.0
SCV 6.0
SnapCenter 5.0
SCV 4.9
SCV 5.0
SnapCenter 4.9
SCV 4.8
SCV 4.9
SnapCenter 4.8
SCV 4.7
SCV 4.8
