Snap Creator Framework
Troubleshooting Domino plug-in-specific errors
Contributors netapp-yvonneo netapp-revathid netapp-aherbin NetAppZacharyWambold
Common Snap Creator errors fall into two categories: generic Snap Creator errors and Domino plug-in-specific errors. Domino plug-in-specific errors typically involve preinstallation issues, bad databases, or problems with a custom restore action.
Note For information about generic Snap Creator errors, see the Snap Creator Framework 4.3.3 Administration Guide.
Domino plug-in is not supported on this platform
You typically receive this error when the prerequisites for the Domino plug-in have not been met. Generally, the error message is similar to the following:
Failed to load plug-in domino. Reason: ERROR: [ltd-00009] Domino plug-in
couldn't be loaded. Reasons could be 1) Domino plug-in is not supported
on this platform.
The following error message has also been known to appear:
ERROR: [tampico:9090(4.1.x)] SCF-00038: Application quiesce for
plug-in [domino] failed with exit code [99], continuing with backup.
As well as this one:
ERROR: [scf-00094] Application environment set for plug-in domino failed
[ERROR: [scf-00060] unknown application object [app] / application domino at snapcreator.pl line 6410.
These errors messages appear if one of the following conditions is not met:
  • Preinstallation steps were not performed or were performed incorrectly:
  • The bit level of Domino is different from the bit level of Snap Creator. For example, if you are using 32-bit Domino, you should use 32-bit Snap Creator.
Snap Creator backup fails because of a bad database
By default, a backup operation will fail if one or more databases are in an inconsistent or corrupted state. You can force the plug-in to proceed with backup operations despite errors, as described in step task using the gui to create a configuration file.
Domino restore using custom action fails
Restore errors typically occur when restore paths are not set correctly. Check the paths for extra characters and backslashes. Also, verify that the Data Restore Directory is set correctly.
Errors are similar to the following:
########## Custom plug-in action ##########
[Thu Apr 19 16:05:55 2012] DEBUG: Restoring to current time.
[Thu Apr 19 16:05:55 2012] DEBUG: Calling dominocore::postRestoreToTime with arguments(C:\Lotus\Domino\notes.ini,F:\Domino\data\,H:\changeinfo\fuji15-daily_20120419130836,-1,F:\Domino\data\restore\mail\dadams.nsf,UP-TO-THE-MINUTE,H:\changeinfo\logs\)
[Thu Apr 19 16:05:55 2012] TRACE: Notes API initialized
Applying Change info for:F:\Domino\data\restore\mail\dadams.nsf
Error: unable to open file 'H:\changeinfo\fuji15-daily_20120419130836/restore_mail_dadams.nsf.info', for path 'F:\Domino\data\restore\mail\dadams.nsf'.
Error:5114
NSFRecoverDatabases failed for database:F:\Domino\data\restore\mail\dadams.nsf
Recovery Manager: Recovery only supported for Backup Files.ERROR_CODE:5114
[Thu Apr 19 16:05:55 2012] ERROR: [ltd-00008] Restoring databases finished with errors
[Thu Apr 19 16:05:55 2012] ERROR: [scf-00154] Action custom for plugin domino failed with exit code 1, Exiting!
[Thu Apr 19 16:05:55 2012] DEBUG: Exiting with error code - 2
All Domino plug-in-specific errors
The following table lists the IBM Domino plug-in-specific error messages in reference format:
Error code Error message Description/resolution
ltd-00001
Domino plug-in cannot work with SNAP_TIMESTAMP_ONLY = N. SNAP_TIMESTAMP_ONLY should be set to Y.
For more information, see step task_using_the_gui_to_create_a_configuration_file.
ltd-00002
Quiescing databases finished with errors
Domino plug-in was unable to put all databases in backup mode. Check the logs to find the exact reason for the error or run Snap Creator in debug mode to find the error.
ltd-00003
Unquiescing databases finished with errors
Domino plug-in was unable to take all databases out of backup mode. Check the logs to find the exact reason for the error or run Snap Creator in debug mode to find the error.
ltd-00004
Discovering databases failed
An application error caused application discovery to fail. Check the configuration and application settings. You can disable automatic discovery by setting APP_AUTO_DISCOVERY=N and commenting out VALIDATE_VOLUMES.
ltd-00005
Collection of operating system information failed - $@
An error collecting operating system information caused the scdump action to fail. Check the logs and try running the command manually.
ltd-00006
Collection of SnapDrive information failed - $@
An error collecting SnapDrive information caused the scdump action to fail. Check the logs and try running the command manually.
ltd-00008
Domino plug-in was unable to restore all the databases successfully. Check the logs to find the exact reason for the error or run Snap Creator in debug mode to find the error.
ltd-00009
Domino plug-in cannot be run as root
Reasons could be:
  • Domino plug-in is not supported on this platform.
  • Prerequisites for the Domino plug-in to run are not satisfied.
ltd-00010
Errors encountered while opening databases
