Custom plug-in in SnapCenter
The custom plug-in created using Java, PERL, or NATIVE style can be installed on the host using SnapCenter Server to enable data protection of your application. You must have exported the plug-in to install it on the SnapCenter host using the procedure provided in this tutorial.
Creating a plug-in description file
For every plug-in created, you must have a description file. The description file describes the details of the plug-in. The name of the file must be Plugin_descriptor.xml.
Using plug-in descriptor file attributes and its significance
| Attribute | Description |
Name  |
Name of the plug-in. Alpha numeric characters are allowed. For example, DB2, MYSQL, MongoDB For plug-ins created in NATIVE style, ensure that you do not provide the extension of the file. For example, if the plug-in name is MongoDB.sh, specify the name as MongoDB.  |
Version  |
Plug-in version. Can include both major and minor version. For example, 1.0, 1.1, 2.0, 2.1  |
DisplayName  |
The plug-in name to be displayed in SnapCenter Server. If multiple versions of the same plug-in are written, ensure that the display name is the same across all versions.  |
PluginType  |
Language used to create the plug-in. Supported values are Perl, Java and Native. Native plug-in type includes Unix/Linux shell scripts, Windows scripts, Python or any other scripting language.  |
OSName  |
The host OS name where the plug-in is installed. Valid values are Windows and Linux. It is possible for a single plug-in to be available for deployment on multiple OS types, like PERL type plug-in.  |
OSVersion  |
The host OS version where plug-in is installed.  |
ResourceName  |
Name of resource type that the plug-in can support. For example, database, instance, collections.  |
Parent  |
In case, the ResourceName is hierarchically dependent on another Resource type, then Parent determines the parent ResourceType. For instance, DB2 plug-in, the ResourceName “Database” has a parent “Instance”.  |
RequireFileSystemPlugin  |
Yes or No. Determines if the recovery tab is displayed in the restore wizard.  |
ResourceRequiresAuthentication  |
Yes or No. Determines if the resources, which are auto discovered or have not been auto discovered need credentials to perform the data protection operations after discovering the storage.  |
RequireFileSystemClone  |
Yes or No. Determines if the plug-in requires FileSystem plug-in integration for clone workflow.  |
An example of the Plugin_descriptor.xml file for custom plug-in DB2 is as follows:
<Plugin> <SMSServer></SMSServer> <Name>DB2</Name> <Version>1.0</Version> <PluginType>Perl</PluginType> <DisplayName>Custom DB2 Plugin</DisplayName> <SupportedOS> <OS> <OSName>windows</OSName> <OSVersion>2012</OSVersion> </OS> <OS> <OSName>Linux</OSName> <OSVersion>7</OSVersion> </OS> </SupportedOS> <ResourceTypes> <ResourceType> <ResourceName>Database</ResourceName> <Parent>Instance</Parent> </ResourceType> <ResourceType> <ResourceName>Instance</ResourceName> </ResourceType> </ResourceTypes> <RequireFileSystemPlugin>no</RequireFileSystemPlugin> <ResourceRequiresAuthentication>yes</ResourceRequiresAuthentication> <SupportsApplicationRecovery>yes</SupportsApplicationRecovery> </Plugin>
Creating a ZIP file
After a plug-in is developed and a descriptor file is created, you must add the plug-in files and the Plugin_descriptor.xml file to a folder and zip it.
You must consider the following before creating a ZIP file:
The script name must be same as the plug-in name.
For PERL plug-in, the ZIP folder must contain a folder with the script file and the descriptor file must be outside this folder. The folder name must be the same as the plug-in name.
For plug-ins other than the PERL plug-in, the ZIP folder must contain the descriptor and the script files.
The OS version must be a number.
Examples:
DB2 plug-in: add DB2.pm and Plugin_descriptor.xml file to “DB2.zip”.
Plug-in developed using Java: add jar files, dependent jar files, and Plugin_descriptor.xml file to a folder and zip it.
Uploading the plug-in ZIP file
You must upload the plug-in ZIP file to SnapCenter Server so that the plug-in is available for deployment on the desired host.
You can upload the plug-in using the UI or cmdlets.
UI:
Upload the plug-in ZIP file as part of Add or Modify Host workflow wizard
Click “Select to upload custom plug-in”
PowerShell:
Upload-SmPluginPackage cmdlet
For example, PS> Upload-SmPluginPackage -AbsolutePath c:\DB2_1.zip
For detailed information about PowerShell cmdlets, use the SnapCenter cmdlet help or see the cmdlet reference information.
Deploying the custom plug-ins
The uploaded custom plug-in is now available for deployment on the desired host as part of the Add and Modify Host workflow. You can have multiple version of plug-ins uploaded to the SnapCenter Server and you can select the desired version to deploy on a specific host.
For more information on how to upload the plug-in see, Add hosts and install plug-in packages on remote hosts
