SnapCenter Software 4.6
Add resources to SnapCenter Custom Plug-ins
Contributors netapp-soumikd
You must add the resources that you want to back up or clone. Depending on your environment, resources might be either database instances or collections that you want to back up or clone.
What you will need
  • You must have completed tasks such as installing the SnapCenter Server, adding hosts, creating storage system connections, and adding credentials.
  • You must have created a custom plug-in.
  • You must have uploaded the plug-ins to SnapCenter Server.
Steps
  1. In the left navigation pane, click Resources, and then select the appropriate plug-in from the list.
  2. In the Resources page, click Add Resource.
  3. In the Provide Resource Details page, perform the following actions:
    For this field…​ Do this…​
    Name
    Enter the name of the resource.
    Host name
    Select the host.
    Type
    Select the type. Type is user defined as per the plug-in description file. For example, database and instance.
    In case the type selected has a parent, enter the details of the parent. For example, if the type is Database and the parent is Instance, enter the details of the Instance.
    Credential name
    Select Credential or create a new credential.
    Mount Paths
    Enter the mount paths where the resource is mounted. This is applicable only for a Windows host.
  4. In the Provide Storage Footprint page, select a storage system and choose one or more volumes, LUNs, and qtrees, and then click Save.
    Optional: Click the add policy from resourcegroup icon to add more volumes, LUNs, and qtrees from other storage systems.
    Note SnapCenter Custom Plug-ins does not support automatic discovery of the resources and the storage details for physical and virtual environments. You must provide the storage information for physical and virtual environments while creating the resources.
    Storage footprint
  5. In the Resource Settings page, provide custom key-value pairs for the resource.
    Use the custom key-value pairs if you want to pass resource-specific information. For example, when you are using the MySQL plug-in, you must specify a HOST as HOST=hostname, PORT =port-no used for MySQL and master-slave configuration as MASTER_SLAVE = “YES” or “NO” (name is MASTER_SLAVE and value is “YES” or “NO”).
    Note Ensure that the words HOST and PORT are in uppercase.
    resource settings
  6. Review the summary, and then click Finish.
Result
The resources are displayed along with information such as type, host or cluster name, associated resource groups and policies, and overall status.
Important You must refresh the resources if the databases are renamed outside of SnapCenter.
After you finish
If you want to provide access to the assets to other users, the SnapCenter administrator must assign assets to those users. This enables users to perform the actions for which they have permissions on the assets that are assigned to them.
After adding the resources, you can modify the resource details. If a custom plug-in resource has backups associated with it, the following fields cannot be modified: resource name, resource type, and host name.
