Space and sizing requirements
Before you install the SnapCenter Server, you should be familiar with the space and sizing requirements. You should also apply the available system and security updates.
| Item | Requirements | ||
Operating Systems |
Microsoft Windows Only English, German, Japanese, and simplified Chinese version of the operating systems are supported. For the latest information about supported versions, see NetApp Interoperability Matrix Tool. |
Minimum CPU count |
4 cores |
Minimum RAM |
8 GB
Minimum hard drive space for the SnapCenter Server software and logs |
4 GB
Minimum hard drive space for the SnapCenter repository |
6 GB
Required software packages |
For .NET troubleshooting information see, SnapCenter upgrade or install fails for legacy systems that do not have internet connectivity. For the latest information about supported versions, see NetApp Interoperability Matrix Tool. |
