Space and sizing requirements
Before you install the SnapCenter Server, you should be familiar with the space and sizing requirements. You should also apply the available system and security updates.
| Item | Windows host requirements | Linux host requirements | ||
Operating Systems |
Microsoft Windows Only English, German, Japanese, and simplified Chinese version of the operating systems are supported. For the latest information about supported versions, see NetApp Interoperability Matrix Tool. |
Minimum CPU count |
4 cores |
4 cores |
Minimum RAM |
8 GB
8 GB |
Minimum hard drive space for the SnapCenter Server software and logs |
7 GB
15 GB |
Minimum hard drive space for the SnapCenter repository |
8 GB
Not applicable |
Required software packages |
For .NET specific troubleshooting information, see SnapCenter upgrade or install fails for legacy systems that do not have internet connectivity. |
