Prerequisites for using the SnapCenter Custom Plug-ins
Before you use SnapCenter Custom Plug-ins, the SnapCenter administrator must install and configure the SnapCenter Server and perform the prerequisite tasks.
Install and configure SnapCenter Server.
Log in to SnapCenter Server.
Configure the SnapCenter environment by adding storage system connections and creating credentials, if applicable.
Add hosts, and install and upload the plug-ins.
If applicable, install Java 1.7 or Java 1.8 on the plug-in host.
If you have multiple data paths (LIFs) or a dNFS configuration, you can perform the following using the SnapCenter CLI on the database host:
By default, all the IP addresses of the database host are added to the NFS storage export policy in storage virtual machine (SVM) for the cloned volumes. If you want to have a specific IP address or restrict to a subset of the IP addresses, run the Set-PreferredHostIPsInStorageExportPolicy CLI.
If you have multiple data paths (LIFs) in SVMs, SnapCenter chooses the appropriate data path (LIF) for mounting the NFS cloned volume. However, if you want to specify a specific data path (LIF), you must run the Set-SvmPreferredDataPath CLI. The information regarding the parameters that can be used with the command and their descriptions can be obtained by running Get-Help command_name. Alternatively, you can also refer to the SnapCenter Software Command Reference Guide.
Set up SnapMirror and SnapVault, if you want backup replication.
Ensure that port 9090 is not used by any other application on the host.
Port 9090 must be reserved for use by SnapCenter Custom Plug-ins in addition to the other ports required by SnapCenter.
