SnapCenter Software 4.5
Prerequisites for using the SnapCenter Custom Plug-ins
Contributors netapp-soumikd netapp-nsriram netapp-asubhas
Before you use SnapCenter Custom Plug-ins, the SnapCenter administrator must install and configure the SnapCenter Server and perform the prerequisite tasks.
  • Install and configure SnapCenter Server.
  • Log in to SnapCenter Server.
  • Configure the SnapCenter environment by adding storage system connections and creating credentials, if applicable.
  • Add hosts, and install and upload the plug-ins.
  • If applicable, install Java 1.7 or Java 1.8 on the plug-in host.
  • If you have multiple data paths (LIFs) or a dNFS configuration, you can perform the following using the SnapCenter CLI on the database host:
    • By default, all the IP addresses of the database host are added to the NFS storage export policy in storage virtual machine (SVM) for the cloned volumes. If you want to have a specific IP address or restrict to a subset of the IP addresses, run the Set-PreferredHostIPsInStorageExportPolicy CLI.
    • If you have multiple data paths (LIFs) in SVMs, SnapCenter chooses the appropriate data path (LIF) for mounting the NFS cloned volume. However, if you want to specify a specific data path (LIF), you must run the Set-SvmPreferredDataPath CLI. The information regarding the parameters that can be used with the command and their descriptions can be obtained by running Get-Help command_name. Alternatively, you can also refer to the SnapCenter Software Command Reference Guide.
  • Set up SnapMirror and SnapVault, if you want backup replication.
  • Ensure that port 9090 is not used by any other application on the host.
    Port 9090 must be reserved for use by SnapCenter Custom Plug-ins in addition to the other ports required by SnapCenter.
