SnapCenter Software 4.5
Prerequisites for using the SnapCenter Plug-in for SAP HANA Database
Contributors netapp-nsriram netapp-asubhas
Before you use SnapCenter Plug-in for SAP HANA Database, the SnapCenter administrator must install and configure the SnapCenter Server and perform the prerequisite tasks.
  • Install and configure SnapCenter Server.
  • Log in to SnapCenter Server.
  • Configure the SnapCenter environment by adding storage system connections and creating credentials, if applicable.
  • Install Java 1.7 or Java 1.8 on your Linux or Windows host.
    You must set the Java path in the environmental path variable of the host machine.
  • Set up SnapMirror and SnapVault, if you want backup replication.
  • Install the HDBSQL client on the host where you will install the Plug-in for SAP HANA Database.
    Configure the user store keys for the SAP HANA nodes that you will manage through this host.
  • For SAP HANA database 2.0SPS05, if you are using a SAP HANA database user account, ensure that you have the following permissions to perform backup, restore, and clone operations in SnapCenter Server:
    • Backup admin
    • Catalog read
    • Database backup admin
    • Database recovery operator
