Prerequisites for adding hosts and installing SnapCenter Custom Plug-ins
Before you add a host and install the plug-ins packages, you must complete all the requirements. The Custom Plug-ins can be used in both Windows and Linux environments.
You must have created a custom plug-in. For details, see the developer information.
If you want to manage MySQL or DB2 applications, you must have downloaded the MySQL and DB2 Custom Plug-ins that are provided by NetApp.
You must have installed Java 1.8, 64-bit on your Linux or Windows host.
When installing a plug-in on a Windows host, if you specify a credential that is not built-in, or if the user belongs to a local workgroup user, you must disable UAC on the host.
The Custom Plug-ins must be available on the client host from where the add host operation is performed.
General
If you are using iSCSI, the iSCSI service must be running.
Windows hosts
You must have a domain user with local administrator privileges with local login permissions on the remote host.
If you manage cluster nodes in SnapCenter, you must have a user with administrative privileges to all the nodes in the cluster.
Linux hosts
You must have enabled the password-based SSH connection for the root or non-root user.
You must have installed Java 1.8 64-bit, on your Linux host.
If you are using Windows 2019 or Windows 2016 for the SnapCenter Server host, you must install Java 1.8, 64-bit. The Interoperability Matrix Tool (IMT) contains the latest information about requirements.
You must configure sudo privileges for the non-root user to provide access to several paths. Add the following lines to the /etc/sudoers file by using the visudo Linux utility. For example,
Cmnd_Alias SCCMD = /opt/NetApp/snapcenter/scc/bin/scc <non_root_user> ALL=(ALL) NOPASSWD:SETENV: SCCMD
non_root_user is the name of the non-root user that you created.
