Types of restore operations for auto discovered SAP HANA databases
SnapCenter supports volume-based SnapRestore (VBSR), Single File SnapRestore, and connect-and-copy restore types for automatically discovered SAP HANA databases.
Volume-based SnapRestore (VBSR) is performed in NFS environments for the following scenarios:
When the backup selected for restore is taken on releases earlier than SnapCenter 4.3, and only if the Complete Resourceoption is selected
When the backup selected for restore is taken in SnapCenter 4.3, and if the Volume Revert option is selected
Single File SnapRestore is performed in NFS environments for the following scenarios:
When the backup selected for restore is taken in SnapCenter 4.3, and if only the Complete Resource option is selected
For multitenant database containers (MDC), when the backup selected for restore is taken on SnapCenter 4.3, and the Tenant Database option is selected
When the backup selected is from a SnapMirror or SnapVault secondary location, and the Complete Resource option is selected
Single File SnapRestore is performed in SAN environments for the following scenarios:
When backups are taken on releases earlier than SnapCenter 4.3, and only if the Complete Resource option is selected
When backups are taken in SnapCenter 4.3, and only if the Complete Resource option is selected
When the backup is selected from a SnapMirror or SnapVault secondary location, and the Complete Resource option is selected
Connect-and-copy based restore is performed in SAN environments for the following scenario:
For MDC, when the backup selected for restore is taken in SnapCenter 4.3, and the Tenant Database option is selected
Complete Resource, Volume Revert, and Tenant Database options are available on the Restore Scope page. |
