SnapCenter Software 4.5
Supported storage systems and applications
Contributors netapp-soumikd netapp-asubhas
You should know the supported storage system, applications, and databases.
  • SnapCenter supports ONTAP 8.3.0 and later to protect your data.
  • SnapCenter supports Amazon FSx for NetApp ONTAP from SnapCenter Software 4.5 P1 patch release.
    If you are using Amazon FSx for NetApp ONTAP, ensure that the SnapCenter Server host plug-ins are upgraded to 4.5 P1 patch release to perform data protection operations.
    For information about Amazon FSx for NetApp ONTAP, see Amazon FSx for NetApp ONTAP documentation.
  • SnapCenter supports protection of different applications and databases.
    For detailed information about the supported applications and databases, see NetApp Interoperability Matrix Tool.
