Supported storage systems and applications
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
You should know the supported storage system, applications, and databases.
SnapCenter supports ONTAP 8.3.0 and later to protect your data.
SnapCenter supports Amazon FSx for NetApp ONTAP to protect your data from SnapCenter Software 4.5 P1 patch release.
If you are using Amazon FSx for NetApp ONTAP, ensure that the SnapCenter Server host plug-ins are upgraded to 4.5 P1 or later to perform data protection operations.
For information about Amazon FSx for NetApp ONTAP, see Amazon FSx for NetApp ONTAP documentation.
SnapCenter supports protection of different applications and databases.
For detailed information about the supported applications and databases, see NetApp Interoperability Matrix Tool.
SnapCenter 4.9 P1 and later supports protection of Oracle and Microsoft SQL workloads in VMware Cloud on Amazon Web Services (AWS) Software-Defined Data Center (SDDC) environments.
For more information, see Protect Oracle, MS SQL workloads using NetApp SnapCenter in VMware Cloud on AWS SDDC environments.
