SnapCenter Software 6.0
Supported storage systems and applications
You should know the supported storage system, applications, and databases.
  • SnapCenter supports ONTAP 9.12.1 and later to protect your data.
  • SnapCenter supports Amazon FSx for NetApp ONTAP to protect your data from SnapCenter Software 4.5 P1 patch release.
    If you are using Amazon FSx for NetApp ONTAP, ensure that the SnapCenter Server host plug-ins are upgraded to 4.5 P1 or later to perform data protection operations.
    Supports non-volatile memory express (NVMe) over Transport Control Protocol (TCP).
    For information about Amazon FSx for NetApp ONTAP, see Amazon FSx for NetApp ONTAP documentation.
  • SnapCenter supports protection of different applications and databases.
    For detailed information about the supported applications and databases, see NetApp Interoperability Matrix Tool.
  • SnapCenter 4.9 P1 and later supports protection of Oracle and Microsoft SQL workloads in VMware Cloud on Amazon Web Services (AWS) Software-Defined Data Center (SDDC) environments.
