SnapCenter Software 4.5
Supported REST APIs
Contributors netapp-soumikd
The resources available through the SnapCenter REST API are organized in categories, as displayed on the SnapCenter API documentation page. A brief description of each of the resources with the base resource paths is presented below, along with additional usage considerations where appropriate.
Auth
You can use this API call to log into the SnapCenter Server. This API returns a user authorization token that is used to authenticate subsequent requests.
Domains
You can use these API calls to perform the following:
  • retrieve all the domains
  • retrieve details of a specific domain
  • register or unregister a domain
  • modify a domain
Jobs
  • retrieve all the jobs
  • retrieve status of a job
  • cancel or stop a job
Settings
  • register, view, modify, or remove a credential
  • configure notification settings
Hosts
  • retrieve host details
  • retrieve the plug-in installed and their resource details
  • add, remove, or modify a plug-in host
  • install or upgrade plug-ins
Resources
  • retrieve resources
  • create, modify, or remove resources
  • protect a resource
  • back up, restore, or clone a resource
Backups
  • retrieve backup details
  • rename or delete backups
Clones
  • retrieve clone details
  • delete clones
Clonesplit
  • retrieve the status of a clone split operation
  • start or stop a clone split operation
Resource Groups
  • retrieve details of a resource group
  • create, modify, or delete a resource group
  • back up a resource group
Policies
  • retrieve policy details
  • create, modify, or delete policies
Storage
  • retrieve storage details
  • create, modify, or delete a storage
  • discover resources on a storage
  • create or delete a share on the storage
Share
  • retrieve the details of a share
Plugins
You can use these API calls to retrieve all the plug-ins on a host and perform different operations.
Reports
  • generate backup, restore, clone, and plug-in reports
  • add, run, delete, or modify schedules
Alerts
  • retrieve all the alerts
  • delete alerts
Rbac
  • retrieve details of users, groups, and roles
  • add users
  • create, modify, or delete roles
  • assign or unassign roles and groups
Configuration
  • view the configuration settings
  • modify the configuration settings
CertificateSettings
  • view the certificate status
  • modify the certificate settings
Repository
  • backup and restore the NSM repository
  • protect and unprotect the NSM repository
  • failover
  • rebuild the NSM repository
