REST APIs supported for SnapCenter Server and plug-ins
The resources available through the SnapCenter REST API are organized in categories, as displayed on the SnapCenter API documentation page. A brief description of each of the resources with the base resource paths is presented below, along with additional usage considerations where appropriate.
Auth
You can use this API to log into the SnapCenter Server. This API returns a user authorization token that is used to authenticate subsequent requests.
Domains
You can use APIs to perform different operations.
retrieve all the domains in SnapCenter
retrieve details of a specific domain
register or unregister a domain
modify a domain
Jobs
retrieve all the jobs in SnapCenter
retrieve status of a job
cancel or stop a job
Settings
register, modify, or remove a credential
displays the credential information registered in the SnapCenter Server
configure notification settings
retrieves information about the SMTP server currently configured to send email notifications and displays the name of the SMTP server, the name of the recipients, and the name of the sender
displays multi-factor authentication (MFA) configuration of the SnapCenter Server login
enable or disable and configure MFA for the SnapCenter Server login
create the configuration file required to setup MFA
Hosts
query all SnapCenter hosts
remove one or more hosts from SnapCenter
retrieve a host by name
retrieve all resources on a host
retrieve a resource using the resource ID
retrieve the plug-in configuration details
configure the plug-in host
retrieve all resources of the plug-in for Microsoft SQL Server host
retrieve all resources of the plug-in for Oracle database host
retrieve all resources of the plug-in for custom application host
retrieve all resources of the plug-in for SAP HANA host
retrieve the plug-ins installed
install plug-ins on an existing host
upgrade host package
remove plug-ins from an existing host
add plug-in on a host
add or modify host
get the signature of the Linux host
register the signature of the Linux host
put the host to maintenance or production mode
start or restart the plug-in services on the host
rename a host
Resources
retrieve a Microsoft SQL Server resource using a key
retrieve a custom resource using a key
modify a resource of the plug-in for custom application host
remove a resource of the plug-in for custom application host using a key
retrieve a SAP HANA resource using a key
modify a resource of the plug-in for SAP HANA host
remove a resource of the plug-in for SAP HANA host using a key
retrieve an Oracle resource using a key
create an Oracle application volume resource
modify an Oracle application volume resource
remove an Oracle application volume resource using a key
retrieve the secondary details of the Oracle resource
backup the Microsoft SQL Server resource using plug-in for Microsoft SQL Server
backup the Oracle resource using plug-in for Oracle database
backup the custom resource using plug-in for custom application
configure the SAP HANA database
configure the Oracle database
restore a SQL database backup
restore an Oracle database backup
restore a custom application backup
create a SAP HANA resource
protect a custom resource using plug-in for custom application
protect a Microsoft SQL Server resource using plug-in for Microsoft SQL Server
modify a protected Microsoft SQL Server resource
remove protection for Microsoft SQL Server resource
protect an Oracle resource using plug-in for Oracle database
modify a protected Oracle resource
remove protection from Oracle resource
clone a resource from the backup using plug-in for custom application
clone an Oracle application volume from the backup using plug-in for Oracle database
clone a Microsoft SQL Server resource from the backup using plug-in for Microsoft SQL Server
create a clone life cycle of a Microsoft SQL Server resource
modify clone life cycle of a Microsoft SQL Server resource
delete clone life cycle of a Microsoft SQL Server resource
move an existing Microsoft SQL Server database from a local disk to a NetApp LUN
create a clone specification file for an Oracle database
initiate an on-demand clone refresh job of an Oracle resource
create an Oracle resource from the backup using the clone specification file
restores the database to the secondary replica and joins the database back to the availability group
Backups
retrieve backup details by backup name, type, plug-in, resource, or date
retrieve all backups
rename or delete backups
mount an Oracle backup
unmount an Oracle backup
catalog an Oracle backup
uncatalog an Oracle backup
get all the backups required to be mounted to perform point-in-time recovery
Clones
create, display, modify, and delete Oracle database clone specification file
display Oracle database clone hierarchy
retrieve clone details
retrieve all clones
delete clones
retrieve clone details by ID
clone an Oracle resource from the backup using the clone specification file
Clone split
estimate the clone split operation of the cloned resource
retrieve the status of a clone split operation
start or stop a clone split operation
Resource Groups
retrieve details of all resource groups
retrieve the resource group by name
create a resource group for plug-in for custom application
create a resource group for plug-in for Microsoft SQL Server
create a resource group for plug-in for Oracle database
modify a resource group for plug-in for custom application
modify a resource group for plug-in for Microsoft SQL Server
modify a resource group for plug-in for Oracle database
create, modify, or delete clone life cycle of a resource group for plug-in for Microsoft SQL Server
back up a resource group
put the resource group to maintenance or production mode
remove a resource group
Policies
retrieve policy details
retrieve policy details by name
delete a policy
create a copy of an existing policy
create or modify policy for plug-in for custom application
create or modify policy for plug-in for Microsoft SQL Server
create or modify policy for for plug-in for Oracle database
create or modify policy for plug-in for SAP HANA database
Storage
retrieve all the shares
retrieve a share by name
create or delete a share
retrieve storage details
retrieve storage details by name
create, modify, or delete a storage
discover resources on a storage cluster
retrieve resources on a storage cluster
Share
retrieve the details of a share
retrieve details of all the shares
create or delete a share on the storage
Plugins
list all the plug-ins for a host
modify a custom resource using a key
remove a custom resource using a key
modify a SAP HANA resource using a key
remove a SAP HANA resource using a key
modify an Oracle application volume resource using a key
backup the Microsoft SQL Server resource using plug-in for Microsoft SQL Server and a key
backup the Oracle resource using plug-in for Oracle database and a key
backup the custom application resource using plug-in for custom application and a key
configure the SAP HANA database using a key
configure the Oracle database using a key
restore a custom application backup using a key
initiate an on-demand clone life cycle of an Oracle resource
Reports
retrieve reports of backup, restore, and clone operations for respective plug-ins
add, run, delete, or modify schedules
retrieve data for the scheduled reports
Alerts
retrieve all the alerts
retrieve alerts by IDs
delete multiple alerts or delete an alert by ID
Rbac
retrieve details of users, groups, and roles
add or delete users
assign user to role
unassign user from role
create, modify, or delete roles
assign group to a role
unassign group from a role
add or delete groups
create a copy of an existing role
assign or unassign resources to user or group
Configuration
view the configuration settings
modify the configuration settings
CertificateSettings
view the certificate status for the SnapCenter Server or plug-in host
modify the certificate settings for the SnapCenter Server or plug-in host
Repository
retrieve the repository backups
view the configuration information about the repository
protect and restore the SnapCenter repository
unprotect the SnapCenter repository
rebuild and failover the repository
Version
You can use this API to view the SnapCenter version.
