Prerequisites for using the SnapCenter Plug-in for SAP HANA Database
Before you use SnapCenter Plug-in for SAP HANA Database, the SnapCenter administrator must install and configure the SnapCenter Server and perform the prerequisite tasks.
Install and configure SnapCenter Server.
Log in to SnapCenter Server.
Configure the SnapCenter environment by adding storage system connections and creating credentials, if applicable.
Install Java 1.7 or Java 1.8 on your Linux or Windows host.
You must set the Java path in the environmental path variable of the host machine.
Set up SnapMirror and SnapVault, if you want backup replication.
Install the HDBSQL client on the host where you will install the Plug-in for SAP HANA Database.
Configure the user store keys for the SAP HANA nodes that you will manage through this host.
For SAP HANA database 2.0SPS05, if you are using a SAP HANA database user account, ensure that you have the following permissions to perform backup, restore, and clone operations in SnapCenter Server:
Backup admin
Catalog read
Database backup admin
Database recovery operator
